Any 5spd. manual PCMs from '94.5 to '97 will work, or if you have an auto PCM you can get it flashed to a manual. I don't have any, but I hope this helps.
the problem is that i did a five speed swap, got the manual harness that runs down to the tranny switched the correct pins, checked all fuses and it will just turn over forever and not fire or act like it wants to fire. No WTS light comes on either. Auto PCM is GONE.
I agree with FordPride and ReBilld it may not be the PCM. I didnt hook up the clutch safty switch and am running my Auto PCM that was in my truck before i did the swap with no issues of lopeing so far. It very well could be the fuse that FordPride is talking about. Just to throw it out there my Injector control module went out on me a while back over night. Cranked fine the day before and the next day just would roll over.
