1992 F350 Speedo
That sounds like a bad connection (loose).
Check the plug at the VSS on top of the rear differential for corrosion and tight fit, if the pins in the plug are corroded, clean them and put some dielectric grease in there to keep moisture out in the future.. Also make sure the rubber seal is still in the plug..
If all checks out there just give the wiring harness under the truck a good looking over, something could have flew up and damaged a wire there..
If any one has had the instrument panel out lately, there's a possibility a plug (there are 2 back there) was not latched in properly..
Good luck, these types of problems leave your hair in fear of it's life.. (from being pulled out by the roots)
bigandblack
08-24-2017 04:21 PM
allen o
12-02-2008 12:40 PM
alteran
05-16-2007 06:20 PM
