Mustang 2 bushing removal
on
Probably the simplest is to take a propane torch and heat the metal center bushing (do this outside). When it gets hot, you can push it out with a screw driver. Then light the rubber on fire and heat the side of the bushing if available. Eventually you can again push the rubber out with the screw driver. Now take a hack saw and assemble the blade inside the metal shell. Cut the metal shell in two places and it should almost fall out by itself.
Now to press in the new bushing. If the bushing goes into a "C" channel you WILL need to make a spacer that fits inside or you WILL bend the control arm pressing the new bushing in.
Well the new bushing diameter isn't the same so back they go tomorrow AM. This looks more like it...
http://m.oreillyauto.com/mt/www.orei...ol+arm+bushing
ludafisk
12-12-2013 06:09 PM
