uk f3 ambulance
#31
Edit - also, I'm unable to save the pictures from the sales listing. May we ask you to post pictures of the truck? Thanks. Stu
#33
Built in South Africa iirc, and specially coach built I'd guess. Never seen any others that resemble them. All are '51s, and I believe six cylinders. The other owners who have joined here haven't stayed real actively involved to help us learn about them. Hope Hans can offer some insights, history of their service, etc. Stu.
#34
#36
hallo Stu
i need a new Water pump and gasket for my 1951 F3 still don't know what size the 6 cylinder flathead motor is, is there different water pumps from 226 / 254 cubic
and is it possible to get some new tires, i need 5 tires 7.50 x 17 where do i order them
and last, brake line mine is steel and rusted, would like some in cobber so they last longer
Thanks a lot Hans j Grundtvig
#37
Hans - your engine will be the 226 cubic inch version. Both the 226 and 254 used the same water pump, 7HA 8501. The gasket is listed as included with the pump. If you have no local sources and must import from the US, my view would be that this is a perfect time to establish yourself and your M-H as customers of Chuck's Trucks in Connecticut. Chuck Mantiglia is the owner and is expert in these trucks. He is my primary parts source for my trucks. Below is his web page.
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
Tires in the 7.50 x 17" size, having the aggressive traction tread, are today limited to the Tornel brand linked below. These are available on eBay, and from Coker.
https://www.cokertire.com/750-17-tor...on-10-ply.html
Brake lines to my view should be steel. I redid mine myself after buying a quality double flaring tool. Others can speak up if they have other viewpoints. Stu
19fifty4
13
03-10-2012 12:50 PM
va51f1
10-14-2009 09:02 AM
