weird odometer problem
my odometer went haywire. after researching I found this can be somewhat common with an easy fix of soldering a bad connection.
I open up the cluster and resolder the known bad connection and inspected everything else.
Here is what the odometer looks like........
this is what i found.........
Here is the backside where that wire should have gone through.........
Here is it after resoldering that wire back in.............
Any ideas what i can do? The odometer did not change one bit after soldering that wire back in.
If the worst case scenario occurs a guaranteed used cluster could probably be had from eBay rather affordably for the most part.
Those PMOS boards would almost certainly be double-sided, the component density suggests that.
Without a working knowledge of that specific board and circuitry the average electronics shop won't be much help.
Not good news I know but having dug into a few of the older style analog odometer clusters a schematic or deep working knowledge is about the only way to effect most repairs such as the OP is experiencing.
Best of luck with this.
dwhawkins89
11-27-2015 12:20 PM
