360FE - 390FE 428 crank question
I have a 74 fe block it had a 360 crank in it and I have a 1968 428 cobra jet crank to put in its place. What will I need for Rods and pistons? I have 428 rods already just wondering what I need to do. The rods are C7AE-B and the pistons as well. Also what would the cubic inch be when I'm done?
Any help would be greatly appreciated.
-Scott
-Scott
You must use the short FE rods. I used THESE pistons in my build. They put me at about 9.2:1 compression. They are forged, and require the rotating assembly to be balanced. Period. Since the assembly must be balanced, I just used my 352 flywheel and balancer.
THESE are cast (like stock) and should put the compression in the 9.5:1 range. The rotating assembly wouldn't have to be balanced if you found a 410/428 flywheel. The stock balancer will work.
With a .30 overbore you'll end up with a 416
Most of the 390 truck engines used 410 pistons and bear the "410" numbers.
[QUOTE=1972RedNeck;12816210]You must use the short FE rods. I used THESE pistons in my build. They put me at about 9.2:1 compression. They are forged, and require the rotating assembly to be balanced. Period. Since the assembly must be balanced, I just used my 352 flywheel and balancer.
That's fine, but you just created a lot of work for the guy that is balancing the engine. Which could have cost you more then getting the right flywheel. Because of the combination's people come up with, we use to charge by the hour to balance a rotating assembly.
oldmaninva
18
02-18-2006 05:23 PM
brennamp
04-14-2005 08:35 PM
76390baby
04-06-2004 08:04 PM
millertime300
12-03-2003 08:09 PM
hotrodfeguy
07-20-2003 04:30 AM
