6.0L Transmission Cooler Swap
This is my first post but I have followed this site for years... I have learned a lot and saved myself TONS of $$$ by the advice and info on this site so thank you all.
I know this topic has been discussed a lot and there are lots of great ideas out there... I simply wanted to post some pictures of the tranny cooler swap I did this week... Might help someone else and I'm kind of proud of how it turned out... Also I'm thick skinned so I would gladly accept some productive criticism!
Nothing different about the install of the cooler except the lines... I bent some 1/2" stainless steel tubing (.035" sidewall) that I got from the local hydraulic shop and made some hard lines for about half the replacement... I just went a different route with them than most I've seen... I used the plastic clips off a 6.0L to hold the 1/2" lines in the center and one of the original clips off a 7.3L that is on the frame rail to hold the hoses to the fan shroud.
I'm new to this so if the pic's done show let me know... I really would like to get some opinions on what I've done here.
[IMG]https://www.ford-trucks.com/forums/picture.php?albumid=33859&pictureid=122275[/IMG]
[IMG]https://www.ford-trucks.com/forums/picture.php?albumid=33859&pictureid=122276[/IMG]
[IMG]https://www.ford-trucks.com/forums/picture.php?albumid=33859&pictureid=122277[/IMG]
[IMG]https://www.ford-trucks.com/forums/picture.php?albumid=33859&pictureid=122278[/IMG]
Thanks everyone... Believe me it wasn't easy to get to this point... 1/2" stainless steel tubing DOES NOT bend easily... Fortunately I only wasted about a foot practicing but it's not too pricey... And I had to find a machine shop that could flare the ends because that stuff is so hard my flaring tool wouldn't even make a mark!
ScaldedDog, sorry but what do you mean by OtW cooler???
Excurvelle
02-16-2015 08:18 PM
Marz-68
12-17-2010 03:00 PM
firstrider
10-19-2009 05:16 PM
