410 Build Questions
360 stroke = 3.50, 390 rod = 6.49, 390 car piston = 1.778 compression height.
1.75 + 6.49 + 1.778 = 10.018
Deck is 10.17, so your piston is .152 down the hole.
Even if you figure the 390 4v flat top piston without the small volume for the valve reliefs, you get a 7.569:1 compression ratio. (.040 gasket, 72 cc combustion chamber)
This is why they use the 390 piston, either flavor, on the 352/360 rod, which puts it up the hole a bit. With the same info as above and a 6.540 rod, you get a piston "only" .102 down the hole and a compression ratio of 8.248:1, approximatley the advertised CR for a 360.
So im wanting to find a 360 FE motor and build it into a street eating 410 for my 73. I'm not going to rip out my 390 that is currently sitting in the engine bay because I need a driver. I know I will need a 428 crank for the build and I have found that Autozone sells refurbs (for alot less than any stroker crank). I was pondering just porting and blending and milling (ALOT OF MILLING) and rebuilding the heads myself. Pairing it with a biggish cam, a dual plane aluminum intake, and headers. Personally I would happy pumping out 400 horsepower. I would like to be able to run on 87, but 91 is acceptable. Can I expect 400 from this combo or am I shooting wayyyy to high?
// I got a friend that a Ford FE nut literately, He owns his own 7 bay garage and races Fords, I have a 390 FE in a inboard and was asking him about port matching, smoothing the runners, and opening up the cylinder heads and he came back with he tried that on some GT heads and he actually lost horse power and torque when doing a head job, He thinks the FE mills need back pressure to keep the HP/Torque up on them ??/
I'm going out on a limb here but every body I've talk to says 9-6 to 1 is max on 98 oct that was 5 or 6 years ago and I don't think the gas quietly has gotten any better so you might want to bump it down a couple more on the high side say 9-4 to 1 that's still using high octane??/
LedheadELH
18
09-19-2005 05:05 AM
1962_Fords_rule
16
07-31-2004 04:43 PM
peavynation
18
07-29-2004 08:01 AM
pushinfordy
04-06-2004 10:53 AM
rustygreen76ford
05-07-2003 09:27 PM
