Alternator wiring - Ford Truck Enthusiasts Forums
Alternator wiring
Old 02-07-2013, 10:27 AM
reed1951's Avatar
reed1951 reed1951 is offline
reed1951 is gaining momentum as a positive member of FTE.
Question Alternator wiring
Hey guys I'm wiring up my engine to get it started (basically gonna be a temporary setup). I am running a duraspark II system and a ford alternator with 3 or 4 connections on the back. It has a stator, battery, field, and ground. Could I hook it up like the pics below and be good to go? I wanted to see what you guys thought first.
Old 02-07-2013, 06:41 PM
reed1951's Avatar
Bump to top
Old 02-07-2013, 07:48 PM
roljr's Avatar
roljr roljr is offline
roljr is starting off with a positive reputation.
Try changing tour post to Generator wiring.
Bob
Old 02-07-2013, 07:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
You should be good to go with that wiring.
Old 02-07-2013, 08:07 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
That how I did it. Been working fine.
Old 02-07-2013, 08:21 PM
reed1951's Avatar
Great! Should I run a 10 gauge wire from alternator to battery then splice a 16 gauge to the 10 gauge and run the 16 Gauge to the regulator? Do I even need to use the "I" connector on the regulator?
Old 02-07-2013, 10:58 PM
ALBUQ F-1's Avatar
postin' fool
The I circuit is for an idiot light, that "turns on" the alternator (power from ignition key). Don't splice, the 10 (or 8 ga) wire should be a fusible link.
Old 02-08-2013, 01:29 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
The wire gauge depends on two key items: wire length and charging current.
If you have a 100 amp alternator, I'd use a fatter wire for the charging circuit. If the run is very long (more than 3 feet or so) I would, again, consider bigger wire.
10 gauge will be fine if you have a short run and a 36 amp alternator. If, on the other hand, you have the high output alternator (65 to 100 amp), and you ever end up with a dead battery & jump start the truck, that wire will have to carry a big load for longer than normal...it could melt the insulation and that of any wires bundled to it.
Dan
51 ford radiator and shroud for flathead V8 reed1951 Ford Truck Parts for Sale 2 10-25-2015 08:48 AM
2002 Ford Excursion 7.3 powerstroke volthause Vehicles for Sale 1 06-11-2015 02:52 PM
Well I finally got some new wheels reed1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 08-01-2013 04:10 PM
Help with my duraspark II setup... reed1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-02-2013 10:03 AM
dads old 79 rebuild customrich&matt 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-01-2012 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
