dual fuel tank problem - Ford Truck Enthusiasts Forums
Old 02-06-2013, 09:56 PM
stopp429 stopp429 is offline
stopp429 is starting off with a positive reputation.
Hey everybody i have a 87 ford f250 custom and it has the dual tanks. i filled both tanks and run the rear tank and the needle doesnt move, i switch to the front tank which was full and i have only been running the rear tank and the front tank is at half empty. while the rear tank hasnt used any fuel. any suggestions?
Old 02-07-2013, 08:23 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Each tank has a seperate float level sender inside it and both of yours are messed up.
Old 02-07-2013, 07:51 PM
Well if i try to fill the rear tank it doesnt take any fuel. while the front will take about 5 gallons. so its not a float issue.
Old 02-07-2013, 08:14 PM
bluemtn95ford's Avatar
bluemtn95ford bluemtn95ford is offline
bluemtn95ford is gaining momentum as a positive member of FTE.bluemtn95ford is gaining momentum as a positive member of FTE.
So I'm hearing that when using the front tank, the gauge says half full. And when running the back tank, the gauge wont read at all. Correct?
Or else you're saying that regardless of the tank your switched to, your truck only uses fuel from the front tank??
Old 02-07-2013, 10:25 PM
correct it only uses fuel from the front tank. could it be a bad selector valve and the high pressure fuel pump is just sucking it out of the front because the selector valve is stuck on the front tank?
Old 02-07-2013, 10:39 PM
AndrewW AndrewW is offline
AndrewW is starting off with a positive reputation.
Bypass Valve. Fords are really bad about it, whats happening is while you are using the front tank it is also pumping fuel into the rear tank, basically filing it as you drive
Old 02-07-2013, 10:42 PM
that would explain why there is gas coming out of the rear tank filler neck when i park.
where is the bypass valve?
Old 02-07-2013, 11:24 PM
It is attached to the front fuel pump
Old 02-08-2013, 07:32 AM
ok well here is the weird part. last night i had my neighbor helping me and he is a big time nerd when it comes to wiring and diagnosing electrical problems. we were getting power to which ever tank we selected. The funny part is that you cant hear the fuel pumps. so im getting power to the rear tank when its selected and it shuts the power off to the front tank but the front tank is the one having all the fuel used up and the only valve after the fuel tanks is the selector valve or "dual tank resivor valve".
Old 02-08-2013, 09:07 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Dual Function Reservoir:
Info on both styles: 1983 Ford Bronco '84-89 Fuel Reservoirs pictures, videos, and sounds | SuperMotors.net
The cross-flow issue you are describing is VERY common on this vintage truck.
Old 02-08-2013, 09:08 AM
rla2005's Avatar
Quote:
There is no Bypass Valve. I assume you are referring to the Dual Function Reservoir?
Old 02-14-2013, 10:22 PM
ok thanks its just weird how no mater what position the switch on the dash is in (front or rear tank) it only uses fuel from the front tank.
Old 02-15-2013, 06:42 PM
rla2005's Avatar
Quote:
The link I posted above describes how the reservoir works. More than likely the switching valve is stuck in one position.
Dual Fuel Tank Issue SouthernBlues 1987 - 1996 F150 & Larger F-Series Trucks 1 02-02-2017 05:39 PM
Couple dual tank issues Iantiler Fuel Injection, Carburetion & Fuel System 17 02-08-2014 01:30 AM
1996 Dual Tank Problem Big350 1987 - 1996 F150 & Larger F-Series Trucks 1 11-11-2013 11:31 AM
89 F250 dual fuel tank kjg58 1987 - 1996 F150 & Larger F-Series Trucks 7 01-29-2008 09:25 PM
Dual Tank Problem rdcjp Fuel Injection, Carburetion & Fuel System 3 03-04-2006 09:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
