2002 7.3L cranks but wont start. HELP!
Old 02-06-2013, 09:28 PM
r_paetzold's Avatar
r_paetzold
r_paetzold is offline
Hey yall. I have a 02 f250 7.3L just recently it stop turning over, it cranks but wont start. I did get it to start the other day just fine but went out again today and it cranked but wouldnt start again. fuel pump is does have pressure. Any ideas appreciated.
Thanks, Ray
Old 02-06-2013, 09:55 PM
redford's Avatar
redford
redford is offline
Received 1,550 Likes on 905 Posts
Hello r_paetzold and welcome to FTE.
You should be asking your questions in the 7.3L Power Stroke engine forum. They can help.
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
I would suggest checking the CPS, but ask the engine forum before you take my word for it.
Old 02-06-2013, 09:57 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Hello Ray and welcome to FTE.
I've moved your thread to the 1999 - 2003 7.3L Powerstroke Diesel forum because as redford suggested, you'll likely receive assistance here more quickly. These folks are great.
Old 02-06-2013, 10:22 PM
gengine's Avatar
gengine
gengine is offline
Any smoke from your tail pipe? If so what color? You can move your right mirror to look while your cranking. How about the tach, what does it read while you are cranking? How is your oil level? And the oil level in your HPOP? Have someone with a multi meter take a reading off your right battery while cranking. Your truck won't fire below 10.7 vdc IIRC. Let us know these things, and we can start helping you rule things out. One last thing, check fuse 30. If it's bad, unplug your fuel bowl heater and replace fuse.
Old 02-06-2013, 10:38 PM
Reckless's Avatar
Reckless
Reckless is offline
Recommend you do an "Advanced" search (see top menu bar at the top of page) targeting this section of the forum for Hard Start, No Start threads and take some time to read thru them. You will see a common theme and series of steps walking you thru the basics like gengine has asked. This is has been a very common topic the past few months including me.
Old 02-07-2013, 08:38 AM
r_paetzold's Avatar
r_paetzold
Update
Batteries are good, No tac, when truck is cranking, and I do get smoke out of the tailpipe and it is grey in color. any ideas? Thanks
Old 02-07-2013, 08:51 AM
howellt39's Avatar
howellt39
howellt39 is offline
No tach? Do you have a spare cps ?
Old 02-07-2013, 09:13 AM
r_paetzold's Avatar
r_paetzold
No tac when cranking. I am going to get a CPS this evening
Old 02-07-2013, 09:40 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
I keep a CPS in my glove compartment with a 10mm wrench. Comes in handy when you need it!
Old 02-07-2013, 11:31 PM
Reckless's Avatar
Reckless
Reckless is offline
So whaddup? No tach reading and darker smoke? She's trying to fire up. Were ya able to get to the CPS replacement in and did it do the trick? Inquiring minds...blah, blah, blah.
Old 02-08-2013, 02:53 AM
1fixitman's Avatar
1fixitman
1fixitman is offline
The real question about the CPS is Will he get a OEM CPS to install. Most of the aftermarket CPS's don't work worth a number 2 pile of doo doo LOL. Keep your sensors OEM.
Guzman
03-03-2018 05:25 PM
SpeedyBolt
02-06-2015 10:11 PM
mjtpolice76
04-05-2014 07:54 PM
Hyside5
05-08-2007 08:35 AM
markjerry
06-29-2006 06:19 AM
Quick Reply: 2002 7.3L cranks but wont start. HELP!
