1999 Ford F250 Turbo Diesel problems
Just recently my truck (1999 Ford F250 7.3 Diesel 6 speed) is having problems. It seems as if my turbo is going out or maybe my waste gate is going out. I went to Colorado for my winter break and didn't drive my truck for a few weeks. I came back and started driving it around and noticed my turbo seems like it is acting different. It works most of the time through 1st-3rd gears, then 4th gear is kind of less than 1-3, and then 5th and 6th gear the turbo seems to work 10% of the time. Usually I can hear the turbo after 2,000 RPMs, but now 4th gear and up it is just mostly all engine with the occasional turbo. It's weird, the engine is louder when the turbo kicks in, and quiets down when the turbo erratically works. I also noticed some black smoke behind me once when I was hard on the gas, which has always been very miniscule.
So I'm thinking that my turbo is going out, but then kind of thought, maybe my waste gate is stuck open. I don't fully know though and don't know much about diesels to diagnose this problem. Any help is very appreciated! I want to fix this bad boy so it can drive well again. Also it is tuned on the second setting of my Bully Dog programmer (which I'm about to take off for now) and I haven't put any diesel in it since mid December because I have other vehicles to drive. Thanks everyone!
Hello Mitchellbade. Welcome to FTE.
Try asking your question in the 7.3L Power Stroke engine forum.
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
There are some very smart and helpful members in that forum that can assist you.
Would recommend starting with the easy stuff. Intercooler boots and plenum boots on and tight? They can blow off if you get on it (ask me how I know). Search for boost leak detector and you'll find a couple threads on a very inexpensive way to make a boost leak detector out of a 4" PVC cap and how to discover leaks.
Do you have any gauges? Any idea what boost you're generating.
After checking for boost leaks, you can check your up pipes for leaking, evidenced by black soot. In case you're unfamiliar, these are the vertical pipes from your exhaust manifold to the turbo. The donuts that seal them wear out and you can lose a lot of exhaust pressure.
Then, pull and clean your EBP sensor. Search youtube for "7.3L powerstroke mileage" and there's a great video on doing this. Very easy.
Others will be along. How many miles and is this an early 99 or late 99?
Well it has been figured out, it has something to do with my stupidity. Boot came off from the up pipe to the turbo. I'm just going to go back to hiding under a rock now! D'oh!
Errrrik
07-11-2018 02:08 AM
kenm
08-07-2008 11:49 AM
