OK, insert the ignition key, turn the switch to the "Run" position, EDIT: insert the lock cyl & align/rotate so the actuator pin aligns with the lock cyl housing access hole, so the actuator pin snaps into the lock cyl housing retainer hole.
Are you certain the ignition switch is properly aligned with its index marks????
Make sure the switch rack is in the proper position , and the spacer disc is indexed correctly . If the column was apart , some alignment issues can happen .
