Intake manifold runner control valve - Ford Truck Enthusiasts Forums
Old 02-06-2013, 11:18 AM
michaelcast michaelcast is offline
michaelcast is starting off with a positive reputation.
hey i have an 04 f150 lariat with a 5,4 in it and 220km on it, i replaced all the plugs about 8 months ago and had to replace various coils on separate occasions. There is a pretty bad misfire (bad enough to make my CEL blink) and when I plugged it in it said that cylinders 3 and 7 were misfiring which i assume is just coils but I also got the code P2006 indicating that my intake manifold runner control valve is stuck closed, I'm just wondering what the possible problems are that can cause this, do I simply replace the imrcv, if so is it an expensive part? can i just clean it? is it electronically controlled or vaccum controlled? I had used a hypertech programmer in the past but it is currently on stock settings and I replaced the intake manifold gasket once as well so I might of messed something up then, please help! any tips on how to inspect these parts would be great, pictures are always nice to have to
Old 02-10-2013, 04:44 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum. I'm not sure how the runner valves are controlled. Usually vacuum. I would check all of the vacuum lines first. If you can reach the actuator, you should be able to move it by hand with the engine off.
As for the misfire, could just need new coil boots.
Old 02-11-2013, 04:05 PM
i changed the coils and a spark plug misfire is gone, then i changed the imcrv but when i put it all back together the engine codes P2004 and P2006 both came up so now the intake manifold runner control valve is stuck open and closed....i read in another forum that if you move the actuator by hand before installing it that that can cause these codes to come up..is there a way that i dont have to buy another actuator ? and Lxman1 the actuator is electronic
4.6 Liter - Intake Manifold Runner Control jee98 1997 - 2003 F150 3 01-21-2016 12:54 AM
1999 Ford Countour with 2.5, got some questions. Sycostang67 General Automotive Discussion 2 02-26-2015 02:19 PM
They say its the Intake manifold runner control kowen1971 2004 - 2008 F150 1 02-20-2015 05:23 PM
2002 Escape Random Misfire, High Idle, and CAT prob fixed... WB4IUY Escape & Escape Hybrid 0 07-13-2014 03:01 PM
2003 F150 4.2L V6 Auto 2WD Code P1518 dandydon 1997 - 2003 F150 10 06-06-2011 07:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
