old front wheel alignment charts - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 02-06-2013, 12:29 AM
Rusty_S's Avatar
Rusty_S Rusty_S is offline
Rusty_S has a great reputation on FTE.Rusty_S has a great reputation on FTE.Rusty_S has a great reputation on FTE.Rusty_S has a great reputation on FTE.
I just recently got a faster/camber tool to set my front end but I'm having a hard time finding the charts that list the number of flats to be turned on the WA-25 tool I have. I have the alignment specs but without the front wheel alignment chart providing the degrees and how many flats to turn the tool I have is useless.
So my question is, does anyone know where to find said charts or have access to one for 1978 ford/mercury?
Old 02-06-2013, 08:19 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Is that a Rotunda tool or set?
Old 02-06-2013, 08:38 AM
Rusty_S's Avatar
Quote:
I got a snap on version of the tool as the rotunda version was impossible find on short notice. It appears identical to the rotunda version with a part number of T69P-3000-A.
I assume since this is a snap on version of the ford one for ford/mercury/Lincoln faster/camber I assume the same charts can be used. If not the I just wasted $29 on this tool.
Old 02-13-2013, 04:26 PM
Rusty_S's Avatar
I just bought a ford alignment chart but its for 1975 - 1976 body on frame vehicles. Question I have is would the charts still be useable for a 1977 - 1978 vehicle?
Only reason I ask is cause I am being delayed on the last few coponents coming inand I got this chart and if it will work I will be set otherwise I will have to keep looking for the correct chart or fork out more money to buy a caster/camber gauge.
part # of the chart I got is CTP-1976-5A
Old 02-16-2013, 08:59 AM
JWA's Avatar
JWA JWA is offline
You might check out Motorcraft.com as they seem to have quite a bit of downloadable older specs and charts---I use it for their replacement pigtail leads and connectors.
Failing that I'd call an independent alignment shop and see if they'll share a bit of info with your particular year and model. About half the time you'll find someone willing to share a bit of their knowledge, as long as you don't want to talk all day!
You might also check on eBay in the Motors section and then in the Manuals/Literature sub-category. Here's an example: Manual Hunter Wheel Align Spec 73 82 MES1057 | eBay
HTH
rotunda caster/camber tool # T69P-3000-A Rusty_S Brakes, Steering, Suspension, Tires, & Wheels 2 01-31-2013 11:29 AM
Ford Truck Grille Chart? coopdad General Automotive Discussion 2 01-04-2013 09:27 PM
Alignment appointment OleGrouch Excursion - King of SUVs 3 08-17-2012 11:37 PM
F350 Specs Chart stone75 6.4L Power Stroke Diesel 1 04-16-2007 02:19 AM
Lubrication chart available? DaveGeof 1999 to 2016 Super Duty 0 03-28-2003 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
