David - How can you tell about the bed? The shot is soooo dark I can't tell anything. That truck looks good, but even Dad's truck would look fair in the dark.
Yeah i was told a tree fell on the original bed so they replaced it. But there's only one spot where its trusted through and its a small patch behind the rear passenger wheel. Other than that it seems in great shape, ill try to get some lighter pictures of it up tomorrow.
Would a site like photobucket work better? Like I said I'm still new to this :/
In my opinion, they are all irritating to figure out and use.
For you.... to create an Album....
- Go HERE and create yourself a new Public album
- Uload some pictures into it, save the changes
- Click on a picture you want to put into a post
- Copy the BB Code that shows up below the picture. Green-highlighted stuff here:
- Paste that text into your post
- Preview the message to see how it will look (will probably have to use the Advanced editor to do that). Submit it when you're happy.
Sit back and feel good at having accomplished something.
The same thing needs to be done if you use Photobucket or any other hosting site but the specifics of how you do it are different, you get to figure it out.
Just thinking out loud, could you use the 80-86 Bed sides on an 87-up bed?
Yes.
If a 87 to 96/97 bed will fit, then so should an 80 to 86 fit a 87 to 96/97. The frames were more or less the same, with differences in how the front bumpers mounted and the front body panels.
Most people use the 87 to 96/97 model beds because of the fact that they're not as old, possibly had better paint and metal, and are more commonly seen on the roads than the 80 to 86 trucks. They're also usually in better shape.
I see way more 87 to 96/97 models than I do 80 to 86.
1983, I was referring to the repair panels - the full bedsides, not the whole bed. I'm wondering if you could use the 87-up bed as a donor and use the 80-86 quarter panel/bedside so it looks like the 80-86 bed. The wheelhouse is different but that could be changed. This way if you don't have a bed or yours is rotted/beat beyond repair it's an option.
