F250 tune-up
F250 tune-up
Hi i have an F250 v8 superduty 5.4 liftes 4" with 35's and i want to do a tuneup on it but not sure really of what that consists of if i could just get a list maybe of what that would consist of i have most tools i need but basically looking to do most myself and whatever i have to have garage do ill pay for it i just wana get out as cheap as possible by doing most myself thanks
What year is the truck?
For my tuneup, I did air filter, spark plugs, fuel filter, and oil/filter. Couldn't hurt to flush the coolant and replace the thermostat too.
Take a look at these writeups: 2004 F250 Super Duty 4x4
Jason wrote those articles and his user name on here is 1975StroppeBaja.
Wizkid gave you a good start, about the only thing I would add would be new COP boots, and cleaning your MAF sensor. That would be about it for an engine tune-up. If you wanted to go over everything, then you could add a flush and fill for everything, transmission, transfer case, and front and rear axles. Give your brakes a good once over, maybe flush brake fluid as well.
Like he says though, we need to know the year, there's different quirks for different years.
This is just what i used on my old truck
Coolant flush - ford gold
Trans flush - valvoline mercon V
Plugs - motorcraft platinum
oil change - valvoline 5-20 durablend and motorcraft filter
transfer case - mobil 1 ATF
rear diff - mobil 1 gear oil (cant remember but think its 75-140? and it has the limited slip additive in it already) and i would just toss an 08+ ford aluminum cover on because they are cheap enough
brake fluid - valvoline synthetic brake fluid
power steering fluid flush - mobil 1 atf
pcv valve - motocraft
just what i did and fluids i like
i must have had a coupon or something cause i am positive they were under $25, but either way, still not even $30
Buy Motorcraft Original Equipment Platinum Iridium Spark Plug SP479 at Advance Auto Parts
Buy Motorcraft Spark Plug SP515 at Advance Auto Parts
