chassis swap question
If you want a slick 4wd f250 I hope to be selling mine in 2or 3 years
JW, I believe the 65-66 4wd might work, 2wd no. Garbz (username here) or number dummy should be able to lay it out correctly.
FYI 2wd: In 65 Ford introduced the Twin I-beam and kept it the same through 79. Cab floors, firewalls, and most all below the chassis front is bolt hole exchange. That is why many of us run power steering & disc brakes under our Slicks.
The 64 back 2wd are in a different world.
John
John
justforkicks
13
11-16-2014 01:38 PM
bulldogjake93
12-19-2004 09:53 PM
