replacing timing gears - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 02-05-2013, 02:38 PM
jake matthews jake matthews is offline
jake matthews is starting off with a positive reputation.
i found a 1985 bronco II that needs new timing gears and i want to fix it then sell it.
i would like to know how hard of a job it is on the 2.9l or if it is even worth it
Old 02-05-2013, 09:12 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
The 2.9 does not have timing gears, it has a conventional sprockets and chain.
The 2.8 (what a 85 will have) has timing gears, and are relatively simple to replace if you have the tools and good mechanical abilities.
Old 02-05-2013, 09:18 PM
thanks I meant to type 2.8.
Old 02-06-2013, 10:42 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Yes, the 2.8 has gears, the orig. ones had a steel crank gear and a fiber cam gear, the new ones will be steel crank, and alum cam gear. They have to be installed as a set, the teeth angle is off a little and won't match well with the orig. To change the crank gear you need to drop the oil pan for enough clearance to remove the gear.
89 F150 4.9L Timing Gear Replacement mastersergeant Ford Inline Six, 200, 250, 4.9L / 300 24 03-27-2017 11:20 AM
wont go into gear big-B Excursion - King of SUVs 6 12-26-2015 06:49 PM
240 cid timing gear spear1up Ford Inline Six, 200, 250, 4.9L / 300 4 10-22-2013 01:33 PM
Gear Shift locked daypray1 2004 - 2008 F150 7 05-20-2008 05:51 PM
gear drive timing hans88 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 04-26-2006 10:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
