Lifted Truck With A Snow Plow?
JUST wondering if anyone on here has a lifted truck that they plow snow with?Im goingto be putting on a 6" skyjacker on my truck that has a 3" body lift on it now and ive seen trucks like his here where i live.has anyone here lifted there truck that they plow snow with andwhat they had to do to it?thanks!
I had a 1985 GMC 3/4 ton 4x4 with a 4" lift in it and you could still plow with it but, the angle was not right. with the 6" lift you will probably need to find a way to drop your frame brackets(push plates), on the truck, down lower. an adaptor plate or some mods to the original plates will need to be made by a fab shop. keep in mind that these plates are going to stick down at the front, under the bumper and affect your ground clearance alot. wouldn't that negate the purpose of the lift kit a little? maybe a real crafty fab shop could make up some push plates that detach easily from the frame so that in the non-plowing months you can be without them altogether. these plates have to be very very rugged as they transfer a huge amount of stress up to the frame. let us know what route you take.
hmm not sure what im gonna do yet i picked up my 6" skyjcker lift today man those leafs are heavy.anyway i have the old frame mount fisher snow plow.i know i can weld some steal on the plow to make it get to the frame.as far as off roading i may do a little bit but im doing it more for the look i guess not that i dont wanna go off roading but where is there to go here in connectict?anyone?
Sick6
51
09-27-2017 09:32 PM
