Best way to carpet - Ford Truck Enthusiasts Forums
Best way to carpet
Old 02-05-2013, 11:55 AM
gsato55 gsato55 is offline
gsato55 is starting off with a positive reputation.
Best way to carpet
Hi All,
I finally laid the carpet in my grandson's 56 F100 to see what problems I might encounter. The master cylinder fill hole, battery and because I used the 53-55 gas tank all must be accessed somehow by either cutting out the carpet or somehow being able to remove the carpet for access. Any ideas are welcome.
Old 02-05-2013, 12:19 PM
South of BC's Avatar
South of BC South of BC is offline
South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.
It's best to keep the pets out of the car!
I'd suggest not gluing the carpet down, but use velcro strips to keep it in place so you can lift it to access. But being a floor mat guy (literally and figuratively!) I haven't the experience.
Old 02-05-2013, 01:15 PM
Rich56's Avatar
Rich56 Rich56 is offline
Rich56 is gaining momentum as a positive member of FTE.Rich56 is gaining momentum as a positive member of FTE.
Tucked mine under the door sill plates and Velcro up under the firewall.
Old 02-05-2013, 01:45 PM
I appreciate the help guys. I thought maybe the velcro way may be the answer. Rich 56, I really like your interior. Where did you get the sill plates from?
Old 02-05-2013, 03:58 PM
Rich56's Avatar
Old 02-05-2013, 04:08 PM
Just curious Rich, do you have to remove the sills to lift the carpet, or is it just tucked under?
Old 02-05-2013, 04:26 PM
Rich56's Avatar
Have to be removed, PITA.
Only reason would be to access battery.
Old 02-05-2013, 04:40 PM
Thanks Rich56. I found them in the catalog.
Old 02-05-2013, 11:44 PM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
I am fitting a drop down battery box to my 56 to avoid the carpet lifting exercise, been there before, what a P.I.T.A. LOL John
Old 02-05-2013, 11:57 PM
Dobies4life's Avatar
Dobies4life Dobies4life is offline
Dobies4life is starting off with a positive reputation.
Having never done auto carpet before...
Is it best to just lay it down or do some sort of stretch on it like house carpeting?
I would think if it was just laid down it would stretch the fabric over time and leave wrinkles. Just like my 65 merc has in it...
Old 02-06-2013, 11:59 AM
Look at Rich56"s carpet and see how nice and tight it is. I took the advise of using 2" wide velcro glued to both sides after stretching and it seems to hold just fine. But before doing that, I installed all-thread in all the mounting holes. In most of the holes in the floor, I installed gripserts, but you can install a short bolt from the bottom and lock it down with a nut to achieve the same result. I then drilled some different sized round stock on my lathe to press over the studs. I then heat the round stock with a propane torch and push it over the studs and walla, you have cauterized holes. You can also use a single edge razor blade and cut an x on the stud and achieve the same results. Hope this helps someone.
Old 02-06-2013, 03:19 PM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Saw a guy that used snaps. I think that's the way I want to do mine when I'm ready
Old 02-07-2013, 10:11 AM
SVT-F100's Avatar
SVT-F100 SVT-F100 is offline
SVT-F100 is gaining momentum as a positive member of FTE.
hmmm Snaps... I really like that idea, only if the snaps are strong enough to take the beating of snapping and unsnapping. Hate for one to rip off... Any one have snap on carpets?
Old 02-07-2013, 10:15 AM
SVT-F100's Avatar
I found this place that primarily does boats. Looks like you can do custom orders (sounds expensive) but better you can just buy the snaps and tool to install them your self.
Custom Marine Carpet
I am ways away from interior but sounds like a decent ideas so far.
Passenger side carpet wet!!?? scott79 6.0L Power Stroke Diesel 23 08-31-2016 05:24 PM
Carpet removal for tranny swap? Best approach? gittinwidit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 08-06-2016 08:42 AM
Henry gets carpet 53OlderThanMe 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 03-12-2016 10:30 AM
Rubber mat to carpet upgrade & clutch rod question HIO Silver 1967 - 1972 F-100 & Larger F-Series Trucks 11 08-29-2015 01:39 AM
Carpet for 66 F100 rwrogers 1961 - 1966 F-100 & Larger F-Series Trucks 19 08-27-2014 01:36 PM
Tags
carpet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
