Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 02-03-2013, 11:01 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
lift kit write up
Well I have had my 35" tyres in the garage for about 3 months now and had to get around to my lift kit. The kit arrived the 1st week on 2013 so it was bad time. Had to wait for the kids to go back to school.
I already have 2" of lift in my spring packs, so I decided to go another 3" by way of OUO 5" block/traction bar at the rear and Icon 3" shackle extension at the front.
Here is the rear kit
Click the image to open in full size.
And the front
First up was to remove all the steering Knuckles on the drag link and the bar that runs from the steering box to the dummy box. Alot of heat and a bit of PB blaster then a tap with the hammer and they should pop out.
Then remove the pitman arm. Which aint easy. Heaps of heat and a turn on the puller and repeat the process until it pops off. Once of clean her up, add a bit of anti sieze. Flip her over and put it back on.
Then support the front of the truck via stands and support the front axle via jack
Take out the front pin and then the rear and remove the rear shackle. I had to drill out the Icon rear shackle holes a little bit more to fit my pins. Once that was done they are pretty easy to install
Now the instructions say to fit the front extension and then front pin. I used a bottle jack to push the springs down to fit the extension in.
But I gotta tell ya, getting that pin to line up was a complete PITA. So on the other side I pushed the springs down and put the pin in first and let the whole lot come up as one and it was alot easier
Front kit installed
other side done and shockie in place
Now the rear block are pretty straight forward. Support the rear of the truck with the tyres off the ground. Support the rear axle with jack. Undo ubolts and remove the 2" OEM block. The OUO blocks have adjustable locating pins for the spring packs. I used the Zero setting. Drop the axle down to fit the block and fit on pin. Now I had to cut a fair bit of the Ubolt to fit my socket due to the fact I didnt have a spanner big enough. They are high tensile so I went through a few cutting disks.
Repeat for the other side and do the suckers up. Then onto the bars. Once again the instructions are straight forward and there is not much technical about it. Find a location up the chassis that the front brackets will fit and you can gain access.
Find a point from the front and get the measurement so you can repeat for the other side
Now some say you should follow the angle of the drive shaft and others say just find a clear spot. Obviously I went for the latter.
Now there are 8 bolts on each bracket which need pilot holes and intermediate holes until you are up to 10mm. Thats alot of drilling and there aint much room and the chassis is strong. On the outer side of the drivers side I had to use a battery drill cause there isnt enough room for the electrical drill to go in straight. Take ya time, have a break in between and get it right. That was the hardest part of the whole deal
The front bolt needs a 34mm socket and the only one I had was 3/4 drive so my 1/2 drive torque wrench wouldnt fit. You need 125ft/lb of torque so i just did the mungrel up dam tight. You will also need to stop the bar from spinning so I use some stilsens. It left a little mark but I can only work with what I have.
One last bit of drilling on the coupler and you are done. Oh, you are going to need a 1/2 and 5/8 drill for that which I didnt have. So up to bunnings I went.
All done
The finished product
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #2 (permalink)
Old 02-03-2013, 11:45 PM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 is gaining momentum as a positive member of FTE.aussie_f350 is gaining momentum as a positive member of FTE.
Looks tough mate, what wheels are they.
__________________
Thanks
Andy
My build thread;
http://www.ford-trucks.com/forums/11...ck-thread.html
  #3 (permalink)
Old 02-04-2013, 01:19 AM
these little babies
Fuel D509 Octane - Black - MHT Fuel Off Road Wheels - Aluminum Wheels - Wheels - by 4 Wheel Parts
__________________
Brian
  #4 (permalink)
Old 02-04-2013, 01:38 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Brian, looks awesome. Will you have to get a lift kit for your house to now get the truck to fit under?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #5 (permalink)
Old 02-04-2013, 02:32 AM
Quote:
Was thinking the same thing
__________________
Thanks
Andy
My build thread;
  #6 (permalink)
Old 02-04-2013, 02:40 AM
2005 Ford F-250
Also, how'd you go with the steering, need a pair of drop-pitman arms?
And a drop middle tail-shaft spacer thingy...
__________________
  #7 (permalink)
Old 02-04-2013, 05:57 PM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
Looks real good mate!
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #8 (permalink)
Old 02-05-2013, 01:29 AM
Na, just turned the pitman arm upside down on the dummy box and put it back on. I had an adjust panhard bar which needed a few turns out to match up to the extended panhard bar bracket and there was enough adjustment on the draglink to bring it up.
Had a wheel alignment today. Just the tow angles were out. And they adjusted the draglink a bit more to centre the steering wheel
__________________
Brian
  #9 (permalink)
Old 02-05-2013, 04:08 AM
didnt need a centre bearing spacer? no shudder under acceleration? i know guys that have gone less lift and need it, but also more lift that didnt!!! i get alignment on mine tomoro, steering wheel upside down so hopefully enough draglink adjustment??
__________________
Thanks
Andy
My build thread;
  #10 (permalink)
Old 02-06-2013, 01:31 AM
actually now that u mention it, Im feeling a shudder in the driveline when taking off in first. Its only slight but its there
__________________
Brian
  #11 (permalink)
Old 02-06-2013, 03:56 AM
2005 Ford F-250
The bolts holding the centre mount are quite long. It would be easy to just undo the bolts add spacers, then re-fit - using longer bolts if necessary.
__________________
  #12 (permalink)
Old 02-06-2013, 02:37 PM
Spacer is $30 odd bucks from arb!
__________________
Thanks
Andy
My build thread;
  #13 (permalink)
Old 02-07-2013, 04:45 AM
2005 Ford F-250
Road test report on the new set-up?
__________________
  #14 (permalink)
Old 02-08-2013, 05:31 PM
Nkelly's Avatar
Nkelly Nkelly is offline
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Quote:
Just a heads up bruvva,drag link is good for fine adjustments,but you can go too far and you will lose turning circle left or right,put her up on the jack and get 'me me' to turn it lock to lock while you ae having a look too make your are getting full lock to lock,we need every bit we can get ...
Truck looks totally different,looks good,can i take it for another spin ?
NO,ok i understand
__________________
Bryan.
2005 FORD F250 7.3L, Maxxis BigHorns 35's,16x10 alloy rims,5"Procomp/Icon Vehicle Dynamics lift,AIH Delete,CCV,FRX,HPX, OCR,JW valve body,mag-hytec rear diff cover,wicked wheel,Garrett turbo outlet,F6 chip,Custom 4" to 5" exhaust,All from clay @ RiffRaff,BD big trans sump,Carpc got the ****,got a IPAD in the dash now
  #15 (permalink)
Old 02-08-2013, 11:17 PM
2005 Ford F-250
Go on, at least let test pilot Biggles check that the IC boots are properly on this time !
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
