2008 F250 - domelight question
I did a little research and I'm pretty sure there all the same. So it should just pull straigt down once you get the one side with the pull tabs off. You could put LED lights in while your at it. I just put the Recon set in my Dad's truck and they look pretty good. I think they're brighter, but its more of a different look than brighter. The main light is definitely brighter and the map lights are a little brighter. Its like a bluish/white color. My dad said it looks kind of eerie from a distance.
Either way, heres a link to Recon's website. They have a nice set of instructions for doing the whole light, which you don't need to do the center light but at least you'll have it incase you do. Just scroll down untill you see the the LED dome light install section. Good luck.
http://www.gorecon.com/downloads.php
Last edited by RedDevil460; 02-03-2013 at 08:33 PM. Reason: Forgot to put the link in... duh.
