Roof Rack - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Roof Rack
Old 02-03-2013, 02:12 PM
yuk067 yuk067 is offline
yuk067 is starting off with a positive reputation.
Roof Rack
I saw an Expedition the other day that really caught my eye. It looked really good in a different way. I couldn't make out what it was that was different til I got back to look at mine. It had the roof rack removed. It looked great. I was wondering if anyone has done this before ? Is it as easy as I would imagine or will there be holes and water leaks to worry about , etc? Thanks for your help and info.
Old 02-03-2013, 08:28 PM
mtondreo mtondreo is offline
mtondreo is gaining momentum as a positive member of FTE.
looks like they talked about it here:
http://www.ford-trucks.com/forums/98...k-removed.html
I bet it would like nice without it
Old 02-04-2013, 08:51 PM
this came from another forum but it was a 3rd gen. I did not do this myself - but here is what a member on another forum did.
"I though I'd post this for those looking to do this mod.
It's a ten minute job - you need a flat blade screwdriver and a #27 torx driver. Insert the screwdriver under the rearmost edge of the rear plastic caps on the rack (between the cap and the rubber base) and lift up. The cap will pop off. Repeat for all four caps (screwdriver under the front most edge on the front caps.) FYI. the cap faces outward.
Remove the two torx screws under each cap.
Slide the entire rack rearward to disengage the keyhole locks on the center mount.
Re-install the removed screws, with some rubber washers underneath (the nut-serts are through holes). If you are not going to mount another rack, consider more thorough sealing against water."
Pics of really cool roof racks? 2002exPSD Excursion - King of SUVs 30 07-04-2016 04:10 PM
Your thoughts on..Surco roof racks Slug-O Excursion - King of SUVs 12 10-23-2012 11:10 AM
ford excursion rack DRH 69 Excursion - King of SUVs 16 07-02-2012 05:35 PM
Crew Cab Roof Rack Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 8 10-09-2011 07:04 AM
Roof Cargo Rack nicksdsm 2004 - 2008 F150 6 04-16-2008 11:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
