Engine ID - Ford Truck Enthusiasts Forums
Engine ID
Old 02-03-2013, 11:46 AM
bruce h's Avatar
bruce h bruce h is offline
bruce h is starting off with a positive reputation.
Engine ID
Hi Guys need a bit of help to identify engine
have recently aquired a ford v8 and now need to identify it
was told came out of a 1979 lincoln
Number on block behind starter motor
D7TE A3B 8H4
anybody able to tel me what this is
many thanks bruce
Old 02-03-2013, 12:07 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
If you knew which Lincoln, that might be helpful. But the number translates to the 351M/400 block. 8H4 is your casting date code, August 4, 1978. That would make it a fairly early 1979 Lincoln, as many engines were installed about 30 days from casting/assembly. There may be tags or decals on the valve covers that might give more clues as to the exact size, 351 or 400.
Old 02-03-2013, 12:17 PM
bruce h's Avatar
Thanks Wayne has given me a start point many thanks
bruce
Old 02-03-2013, 12:40 PM
52 Merc's Avatar
The only real difference between the two is the stroke/reciprocating assembly. Both engines are 4" bore. The 351 has a 3.5" stroke where the 400 has a 4" stroke. The block, heads, and external bits are the same. If it's apart, or will soon come apart, that's easy enough to check.
Old 02-03-2013, 12:46 PM
bruce h's Avatar
Great will go and measure the stroke in a while ,, many thanks for your help ,bruce
Engine ID bruce h 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-08-2013 11:53 AM
400 engine id bruce h 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 06-24-2013 02:17 PM
52 F1 dismantle finally started bruce h 1948 - 1956 F1, F100 & Larger F-Series Trucks 46 06-06-2012 04:45 AM
8BA Flathead REbuild bruce91852 1947 and Older Ford Trucks 0 05-04-2005 10:52 PM
Identify 351W 4V H.O. ? bruce r 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-01-2001 10:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
