Engine Temp Gauge Running Hotter Than Normal
I have a 1995 F250 with the 351 Windsor V8, recently i have been getting a higher temp reading on the engine temp gauge. I changed the oil, that didn't make any difference. My radiator and overflow won't transfer the fluid back and forth, it either just spills out of the overflow going over bumps, as well as the radiator itself will not send the fluid into the overflow when running. I checked the hose for obstructions and there was none, the fittings seemed to be air tight, but that may be a possibility. Hoping to hear your thoughts for further investigation on the problem.
76gdmn
06-16-2011 08:58 AM
CUZ'IN PHIL
07-23-2006 08:07 AM
