Temp Gauge
Temp Gauge
Good morning all,
I am hoping you can answer a long question. I have spent this morning searching the forum, but I can't find what I need. In 0 to 25 degF or colder, does your coolant temp gauge rise into the normal range at all, and if it does how long does it take, block heater use, and what kind of driving are you doing?
Thanks, Dave
Thanks, Dave
I believe a thermostat is stuck open, it takes driving on the highway at 65 to 70mph for 15+ miles just to get into the normal range, around town I can drive 17 miles at 35 to 45mph and never reach the cold side of the normal range. This is at 0 deg at over 20 it is quicker but not much.The dealer gave me a tsb showing slow build of cabin heat at idle and gave it back. No fault found. I am curious as to the normal function of the trucks befre I really rattle some cages.
Thanks Dave
Thanks Dave
It's a diesel so they do take longer to heat up. You have intercooler for air, turbo, a heavy block and lots of water and oil to heat up. I would look at the digital temps but I doubt this is a problem, you may want to try a winter front to help speed it up and a block heater on a timer at the colder temps. You can see the digital temp, block heater should get you around 100 to 130 f. To start. My oldie warms up much faster that way.
Your primary cooling system has a dual thermostat. Each of the two devices opens at a different temp. Staggered by design. The first opens at 194° the second at 201°
So your truck has to be fully warmed up before they open.
I can let my truck remote start and high idle at 1100 rpm and at the end of 5 minutes I still have coolant below 80° and have my rapid heat running.
I can drive a couple miles over to the c-store and run in to get a morning drink and still not be 150°
So it doesn't surprise me that you are not seeing the thermostats open for 10-15 minutes after you start driving.
Received 3,546 Likes
on
These things really take a while to warm up. I do not have the rapid heater and my temp gauge will barely be off cold when I get to work in the morning if it is in the low 20s. It is about a 10 mile drive and I'm usually in moderate traffic (about 20 minutes). Thank goodness for heated seats or I would freeze.
Thanks so far for the insight. I was just looking to compare this truck to other 6.7s to determine if it was normal or defective. My 7.3 warmed up in about 1/4 the time this one takes, same routes. I am not talking cabin heat, actually attaining normal coolant temps.
Thanks again for all replys so far, Dave
