EEC related ?s - Ford Truck Enthusiasts Forums
EEC related ?s
Old 02-03-2013, 08:31 AM
Rodney Gates Rodney Gates is offline
Rodney Gates is starting off with a positive reputation.
EEC related ?s
I have a 96 F150 with the 4r70w I bought with a bad trans. I have an aod from my 93 can I use this trans and swap in a MT computer? Also wondering since the 5.0 HO in my truck has the same firing order will the computer run my rebuilt 351 from my 93.
Old 02-03-2013, 08:53 AM
crazyF250's Avatar
crazyF250 crazyF250 is offline
crazyF250 is starting off with a positive reputation.
Is the 93 trans a truck trans if so its the E4OD and will need the comp for that trans also check your electrical plugs for both trans, If I remember rite they are different also. And yes your comp will run the 351w, did your truck truck come with a mass air setup, if so you will be fine to swap over the 351w.
Old 02-03-2013, 10:54 AM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Sorry, that's incorrect. AODs and E4ODs were offered side-by-side.
Your 96 is OBD-II which makes things tricky, as the OBD-II computer uses a different electrical architecture and won't plug into the older style computers. I assume there were MT OBD-II F-150 5.0 computers made, but I've never really seen one.
If you swap the 351 into the '96, you'll need to transfer crank position sensor, crank pulley, crank encoder wheel and possibly the front cover if the '93 doesn't have a provision to mount the sensor.
Old 02-03-2013, 01:54 PM
Thanks for the info. I was planning on trying to find a OBD II MT computer my understanding is all half tons had to be OBD II in 96 and yes my truck is mass air.
Old 02-03-2013, 02:17 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The AOD was never offered behind a 351 in a truck so that's an E4OD you have there, so you'll need an OBD2 5.8/E4OD computer if that even exists and a 5.8 specific crank balancer with the tone ring. You may be better off fixing the 4R70w and then you can use either motor without changing the computer.
Old 02-03-2013, 04:04 PM
It's an aod at some point someone put the 5.8 in the 93 I had and left the aod from behind the original 5.0 in it. It's easy to tell an aod from an e4od since they look nothing alike.
Old 02-03-2013, 05:35 PM
crazyF250's Avatar
The AOD(non electric) was not used in the trucks, They had an AODE for a bit which is similar to the 4R70W, and the E4OD. The non electric AOD was used in cars up to 93. So not sure what you have there.
Old 02-03-2013, 07:01 PM
Trucks never got the AOD-E, they had the AOD, then went right to the 4R70W.
Old 02-03-2013, 07:30 PM
Conanski's Avatar
Quote:
OK that makes sense, you can ignore all our misguided ramblings then and get back to your hunt for a manual trans obd2 EEC.
Old 02-03-2013, 07:36 PM
Conanski's Avatar
Quote:
Originally Posted by crazyF250 View Post
The AOD(non electric) was not used in the trucks, They had an AODE for a bit which is similar to the 4R70W.
No it's the AODE that was never used in trucks, it's got nothing in common with the 4R70w either since it's really just a mechanical AOD with an electrically locking torque converter. This is the trans that appeared in cars for a short time and I know this partially because some of the early 5.0 Mustang EECs have a control parameter for torque converter lockup but nothing else trans related.
Old 02-04-2013, 07:44 AM
Quote:
Actually the AODE is fully electronic, like the 4R70W. The AODE has a locking converter and a single input shaft, like the 4R70W.
The AOD on the other hand has dual input shafts, and 4th gets directly coupled to the engine via the secondary input shaft.
Old 02-04-2013, 09:31 AM
Conanski's Avatar
Quote:
Lots of people and websites mistakenly use 4R70w and AODE as interchangeable names for the same trans, but the fact is there was an actual Ford 4-speed auto trans than had no electronic controls except for TC lockup and it was known as the AOD-E or AODE. If it's fully electronic and fullsize car or truck compatible it's a 4R70w or E4OD.
Old 02-04-2013, 10:18 AM
Sorry that is not correct. The AODE and 4R70W are almost the exact same transmission. They're both fully electronic. You can even swap the valve bodies between them. The main differences are the wide ratio gear-set in the 4R70W and strengthened internals.
The only Ford RWD automatic that only has an electronic converter lockup is the A4LD. That was used in the early Rangers and Explorers.
What RABS computer can I use? RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 6 04-20-2014 08:06 PM
CEL flashing code ? IABill Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 07-16-2010 12:31 AM
which computer do i need j400ex18 1987 - 1996 F150 & Larger F-Series Trucks 3 04-16-2010 04:21 PM
'95 E4od into a '93 F150 w/ E4od Jimkinger 1987 - 1996 F150 & Larger F-Series Trucks 0 05-09-2009 03:10 PM
93 computer Da Crew Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 01-17-2009 03:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
