Stinky's Stick-up
Old 02-04-2013, 10:55 PM
BWST's Avatar
BWST
BWST is online now
Got Data?
If it's releasing before the cup will move, torque that tool in harder - 20ft lbs or more. Sounds like you're not over engaging it to me. Maybe a tap or two on it as you're trying to engage it like JT250 said. A couple of my cups did the same thing until i reefed on it to get a full turn or two. Arrow on the tool pointed towards the valve springs right? Might affect the angle of engagement - I dont know.
  #47
Old 02-05-2013, 06:50 AM
Tugly's Avatar
Tugly
Tugly is offline
  #48
Old 02-05-2013, 07:37 AM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
He was using a different style removing tool. It was more like a tap than the RDP tool, and I believe it actually bottoms out in the cup. I had a couple that I really had to bow up on, and that's saying a lot. I'd estimate 120ft-lbs on one of the rascals. And it didn't go in smooth, it was very squeaky and very jerky threading it in. Took some force.
  #49
Old 02-05-2013, 09:36 AM
BWST's Avatar
BWST
BWST is online now
Got Data?
wow -120ft lbs. i'm not a good judge of force, but I remember it being significant on a couple of them.
The cool thing to look forward to is, when you have to go back under the covers the 2nd, 3rd, 4th and 5th time because one or more cups did not seal, they pull much easier.
  #50
Old 02-05-2013, 10:18 AM
JT250's Avatar
JT250
JT250 is offline
The one I built actually uses a 1"tap with the end cut of so it doesn't bottom out before it bites. Clay doesn't like that style because it creates too many shavings. However you can drop a penny over the hole before you insert the tool to block the shaving.gs from dropping in the cylinder. But even if they did drop.down there you could vacuum them.out.
RICH I promise one like mine would get it out. You a decent fabricator?
  #51
Old 02-05-2013, 10:42 AM
Tugly's Avatar
Tugly
Tugly is offline
That's the answer to the question that was plaguing me: What size tap? I can get the tap and hack the end off with a skinny wheel. I'll nose around the shop for some scraps that can make the top half. I'm trying to stay focused, but I'm growing battle-weary. I have brand new injectors sitting in a box on the bench after buying reman sticks, new intake plenums, new turbo, new bolts, new sensors, fuel mods, T500, two chips, yadda-yadda-yadda. I want that cup out so I can move on to the second of eight cups, then get back to driving a diesel.
  #52
Old 02-05-2013, 10:59 AM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
I may have slightly exaggerated, but with an 18" moment arm, that's only 80lbs of force, and that's not hard for me to achieve.
  #53
Old 02-05-2013, 12:29 PM
JT250's Avatar
JT250
JT250 is offline
You have an email. I forwarded an email with pics that I sent to one of the other guys last year. Should help a little.
  #54
Old 02-05-2013, 02:12 PM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,897 Likes on 1,145 Posts
Rich, you didn't need SNAP... You have enough problems with tools like AE!
That said, I've always wanted one of those..............
Basically just subscribing here for moral support.
What are the plans for the rebuilt injectors?
  #55
Old 02-05-2013, 04:35 PM
clem1226's Avatar
clem1226
clem1226 is offline
Just thinking out loud here:
Would pressurizing the cooling system help break the cups loose? Nothing major, just normal cooling system pressures 15 to 20lbs,......a little phunamatic laxative for stinky?
  #56
Old 02-05-2013, 05:03 PM
Tugly's Avatar
Tugly
Tugly is offline
Got it, thank you for that. I was looking at different tools to buy and $300 to $550 for this one use was more than I'm willing to go right now.
Ryan gave me full credit on them... I just had to pay the difference. I'm glad I have him as a vendor, his customer support is as good as it gets. It's not his fault I'm a schmuck with bad luck and a tired truck.
I can see it now: I go charging into the house with my hand over one eye, blood oozing down my cheek, proclaiming to my wife "Cup's out!"
  #57
Old 02-05-2013, 05:11 PM
clem1226's Avatar
clem1226
clem1226 is offline
That's the spirit!!
If you aint bleedin you aint tryin
  #58
Old 02-05-2013, 05:35 PM
BWST's Avatar
BWST
BWST is online now
Got Data?
That is funny. a little pressure cant hurt (so to speak), but it's likely a fraction of what's needed. It would make a cool sound when it did break loose. Riffraff's tool would catch it.
Darn it, Tugly, I wish one of us was nearby to take a crack at it. It's got to be a confidence problem. Once you crack one free, it's a walk in the park! I'll be in Wenatchee mid April if you can wait...
  #59
Old 02-05-2013, 05:56 PM
Tugly's Avatar
Tugly
Tugly is offline
I think the eye will heal about that time and I can assist... I'll keep handing you cold ones.
  #60
Old 02-05-2013, 06:19 PM
clem1226's Avatar
clem1226
clem1226 is offline
how about...........a cup in the eye is worth two in the hole?
Quick Reply: Stinky's Stick-up
