EEC interchange
EEC interchange
I hsve a computer out of a 1993 F350 that has the following information:
F4TF-12A650-AHA. Does this information matter or could an alternative computer be used. I was informed that there are none of these available and I would need to get mine rebuilt at the factory. I live in the Bahamas so none of the emissions stuff really is needed and it is a manual shift unit with the basic 5.8 engine. Is there a standard computer I could use to replace this one?
It fits 1994 Ford Trucks. If you have a 1993 then post the Calibration number off the drivers door post and we will tell you what computer to get as this one will not fit a 1993 Ford truck. The number you listed is for a CCD Ignition system and the 1993 truck takes a push-start computer.
1994 F-150 Pickup
Application Data:5.8 Liters and w/M.T. and Federal Emissions; w/I.D. #F4TF-AHA
Units are pre-programmed at the factory.
1994 Ford Trucks
F-250 Pickup
1994 Ford Trucks
F-350 Pickup
Alternate/OEM Part Number(s): F4TF12A650AHA, F4TZ12A650AHA, F4TZ12A650AHB, F6PF12A650ELA, F6PZ12A650ELA
1994 F-150 Pickup
1994 Ford Trucks
F-250 Pickup
1994 Ford Trucks
F-350 Pickup
robreynolds
22
03-03-2018 10:01 PM
