Best plugs for 5.4L - Ford Truck Enthusiasts Forums
Best plugs for 5.4L
Old 02-02-2013, 08:33 AM
docweld's Avatar
docweld docweld is offline
docweld is starting off with a positive reputation.
Best plugs for 5.4L
I want to change the spark plugs on my 2007 F150 5.4L. What are the best plugs to put in? E3's??
Old 02-02-2013, 10:02 AM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
Quote:
Just making sure: you do know about the issue of the plugs breaking in two and the extraction tool that you would need to do this job right? As for the replacement plugs, I have not read of too many using e3's on here. There is a champion plug that some have had success with. It's selling point is that it is a one piece plug that won't break on your next change, but some have complained of their truck not running as good on the champions, others say it is fine. Or or course you can just go back with motorcraft.
Old 02-02-2013, 10:18 AM
CelticDevilDog's Avatar
CelticDevilDog CelticDevilDog is offline
New Mexico Chapter LDR
CelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputation
I put the Motorcraft plugs in mine. If you change them every 60-70k and have the Lisle tool then you shouldn't have to worry too much about the breaking.
Old 02-02-2013, 10:22 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Motorcrafts.
Old 02-02-2013, 11:00 AM
docweld's Avatar
Yes I have heard about them braking. I have 69,990 miles on this new to me truck. I started using injector cleaner on the last tank and I will use more this fill up.
So just get Motocrafts? are the one piece now?
Is this the right tool?
Lisle (LIS65600) Broken Spark Plug Remover for Ford Triton 3 Valve Engines : Amazon.com : Automotive Lisle (LIS65600) Broken Spark Plug Remover for Ford Triton 3 Valve Engines : Amazon.com : Automotive
Old 02-02-2013, 11:30 AM
bigunit54's Avatar
yes that is the tool. I think the motorcraft are still two piece but I'm not sure. I think I remember reading that the champions are the only one piece you can get
Old 02-02-2013, 11:39 AM
The motorcrafts are still two piece. I just don't leave them in for the full 100K that manufacture recommends. Yes, that Lisle tool is a must for any 2004-2008 F150 owner.
Old 02-02-2013, 01:14 PM
docweld's Avatar
Thanks, I will order the tool. I have never been a fan of champions but I do not like the idea of the two piece plug. I looked at the E3's and they are one piece, I just do not know how they would run in the truck.
Is 10-11 MPG normal for local short hilly driving with this 5.4L truck?? I just did my first fill up since I picked up the truck with a full tank and it is about 10 give or take MPG. I hope it will not stay like this!!!!
Old 02-02-2013, 04:59 PM
TexasReb TexasReb is offline
TexasReb is starting off with a positive reputation.
I changed mine out at 70K and after much research ended up going with the motorcraft plugs. Found mine at a great price and just could not justify the extra cost for other makes when they are similar too the motorcraft or have a copper electrode instead of a platinum electrode.
Old 02-02-2013, 07:58 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
Later build 2007 5.4's should have factory installed 1 piece plugs.
Old 02-02-2013, 08:55 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
Quote:
Yeah new designed heads with different plugs. I believe they have brown boots on the coils instead of black.
Old 02-02-2013, 09:15 PM
curtk69's Avatar
curtk69 curtk69 is offline
curtk69 is starting off with a positive reputation.
i just changed my [champion] plugs cuz i had a constant misfire/rough idle at 210,000 km. 6 came out no problem but two squeaked and creaked and took twice the force but none broke! luck or cuz of champions??
it already had champions in it for how long i dont knwo but it was misfiring and one plug came out with a completely burned off electrode
Old 02-03-2013, 08:49 AM
docweld's Avatar
Define late build, Mine is a 3/07 build.
Old 02-03-2013, 10:29 AM
bigunit54's Avatar
It's after November of 2007. I don't know if any of them with the new head design would even be 07 models, they should all be 08's.
Old 02-03-2013, 10:49 AM
cb_13's Avatar
If you do decide to run the E3's keep us all updated on their performance. I for one am quite curious as I do not know anyone who has run them in the 5.4 3 valve. I have had decent luck with them in my lawnmower and weed eater though.
2004 F150 5.4L V8 Plugs & Cops ITDave 2004 - 2008 F150 0 02-27-2015 07:00 PM
Spark plug for 2003 5.4L 2Fords1Jeep 1997 - 2003 F150 6 03-27-2014 08:19 AM
Triton 5.4L Spark Plug Removal makthenif 1997 - 2003 F150 4 03-09-2014 05:18 PM
Tune up 5.4L DaGuru373 1997-2006 Expedition & Navigator 4 09-12-2011 09:28 PM
5.4L Champion Plug Gap motown 2004 - 2008 F150 4 07-06-2008 10:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
