Looking at Aftermarket Discs/Rotors/Calipers
at 115K now's the time to replace the brakes.....
What aftermarket Heavy Duty brakes do you guys like and have had experience with?
Want to replace, discs, rotors, calipers.
I want the slotted and drilled rotors BTW
Thanks in advance
Alan from San Diego
Thanks in advance
Alan from San Diego
I did a complete brake system rebuild bout a year ago. After hours of research I decided to go with the Power Stop 1 click set up. The heavy duty/tow pads. Did rotors, pads, calipers all the way around. Also since I was there It only made sense to change all the rubber brake hoses. Went with motorcraft on those. I got most everything from Rock Auto and Summit Racing. The Power stop is the best bang for buck. Just remember to perform the break in process to the "t". I really like these. I havent had the first issue. Also they look pretty good behind my wheels.
