Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 02-01-2013, 10:19 PM
Deyhey Deyhey is offline
Garage is empty, add now
Deyhey is starting off with a positive reputation.
07 freestyle No heat except for on high
Hi,
I have an 07 freestyle that has no heat except when its turned to the highest setting as soon as I turn it down it get cool instantly. I did change the thermostat and the old one did have a weak spring and the engine temp would drop while idling at lease now the engine will hold temp. With the temperature set to the highest settingthe air is hot the only way I can control the temp is to reduce the speed of the fan. I am now thinking it has something to do with the mixing chamber or the temperature sensor. Any ideas or suggestion would be greatly appreciated.
Deyhey
  #2 (permalink)
Old 02-07-2013, 09:26 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a good reputation on FTE.steve(ill) has a good reputation on FTE.
The F150 and Explorer work like this... not sure of the Freestyle.. Hot air from the heater core and cool air from outside are mixed together in a mixing box. There is a motor controlled damper door that you adjust from open to close with the heater **** on the dash. This is called the "blend door" The larger trucks have had troubles with the control arm on the door breaking, or the electric motor drive failing. NOrmally the location is above the transmission hump, below the radio, left of the glove box. You can normally take off the plastic dash section below the radio, above the hump to get access. Some vehicles you have to remove the glove box... I hope this helps. I assume the Freestyle is similar to the Explorer..
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
  #3 (permalink)
Old 02-07-2013, 09:32 PM
steve(ill)'s Avatar
when you turn the blower to HIGH- it probably pushes the loose door closed. more reading ?
Ford Explorer Ranger Enthusiasts "Serious Explorations"® - View Single Post - 3rd gen Explorer Blend Door Actuator Replacement
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
