Tensioner Gasket Failure - Ford Truck Enthusiasts Forums
Old 02-01-2013, 09:44 PM
Fishhawk460's Avatar
Fishhawk460 Fishhawk460 is offline
Fishhawk460 is starting off with a positive reputation.
I want to start by saying I have a 2010 3V 5.4L with 38K miles. Drove to work in Chicago today and while I was driving through the parking garage the engine started to knock loudly and shake. Check engine light came on. I was lucky enough to find a Ford dealership close by and made a b-line to their service center. The service manager first said it was probably the cam phasers which of course was my thinking. After they pulled the engine down they said the motor had the upgraded cam phasers but the little gasket behind the tensioner failed and I lost oil pressure. He said it was at 8psi. He also said this was a known problem. I've never heard this, only talk of cam phasers. Anyway, the cams and roller lifters are scored and need to be replaced and there are shavings in the oil pan. He said the guides are fine so the bottom end should be okay. I almost hope Ford says to put in a new engine. Pretty upsetting for me considering the truck has only 38K miles and has been run easy.
Anyone else experience this?
How to Save Installing 18 of 24 Followers on a Timing Job. macubus 2004 - 2008 F150 3 01-17-2017 10:32 AM
Cam Phasers, Timing Chain, Bad Fuel Economy ??????????? jessecam 2004 - 2008 F150 0 07-22-2014 08:18 PM
2004 F150 3v triton Timing issue after sparkplug break tear down. Please help. dexterslab724 2004 - 2008 F150 3 06-13-2013 04:53 PM
2004 F150 5.4 Cam Phaser Mike(GA) 2004 - 2008 F150 5 05-28-2012 11:24 AM
2005 F250 5.4 Cam Phasers HELP !!!! thomas_e102 1999 to 2016 Super Duty 13 09-05-2010 12:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
