Hub Centric, Nut or Stud Centric. What Years? - Ford Truck Enthusiasts Forums
Old 02-01-2013, 06:54 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Guys, I've installed a Dana 70 from a 1969 F350 C&C under my 1949 F4. The Dana 70 had the 16.5" nut / stud centric wheels which I want to replace. I have a couple of the nut / stud centric 16" wheels, need a couple more.
What years will I find the nut / stud centric wheels?
What years will have the hub centric wheel?
Did the hub centric come along with the Sterling axle?
Can I run the hub centric wheels as a pair on the Dana axle if I use the correct lug nuts?
And as always, TIA.
ray
Old 02-02-2013, 09:02 PM
we287gn we287gn is offline
we287gn is starting off with a positive reputation.
Hello.. not sure how accurate this info is..Just went through this with a buds early 80's cab and chasis.. I believe the changeover year to hub-centric is 1984.
We had a truck with all the wrong wheels on. It needed the nutstud centric wheels.
Hope this helps.
Then somewhere in late 90's the bolt pattern changes to a metric dimension.
Wheels Type Vibrations rock2610d Excursion - King of SUVs 10 06-04-2016 09:03 AM
Hub centric dually wheels moose4x4 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-26-2016 10:31 PM
hub centric vs. lug centric bvanhauen 2009 - 2014 F150 3 01-03-2015 11:39 PM
Wheels/Rims hub centric to bolt centric?? jibronee 1967 - 1972 F-100 & Larger F-Series Trucks 5 12-08-2014 03:52 PM
77 f-350 dually lug centric to hub centric rim swap br42164 1999 to 2016 Super Duty 4 05-23-2013 08:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
