truck has been running great up into this issue.
temp was about 25deg when video was taken.
i never have to plug it in and always get a little smoke at start up.....first few sec of the video it would normally idle much higher than what it was doing.
How long does it take before you can re start it ? It sounds like it runs long enough to drain the HP res .. After it stalls , take a look ,see if its low . 25 is not low enough to gel the fuel. That does not mean it is not running out of fuel .. look in the fuel bowl too ...The CEL may just be the PCM testing ....
