dual shocks
dual shocks
i own a 93 f-150 4x4 ifs front suspension and a skyjacker 6" lift. my friend gave me a brand new set of front shocks, exctly the ones i have on there now. my question is where/how can i buy a dual shock mout bracket. there is already a shock stud on the axle so all i need is the bracket that holds the existing shock and coil spring. Thanx.
-Jason-
-Jason-
dual shocks
be careful when installing dual shocks. I have seen dual shock setups crack frames over time. I guess the shocks I saw were too stiff, or the wrong legnth. I know dual shock setups look cool, but if the shocks you have on now dampen the ride adequately, i imagine that doubling the dampening ability will create a harsh ride and i can see how that can lead to frame cracking. my advise is to purchase a dual shock setup from a reputable parts supplier, one with softer shocks made for a dual set up
cut me and i'll bleed ford blue
edenroadmaster
edenroadmaster
dual shocks
When you get dual shock kits from lift companies they are specifically designed to have 2 shocks running together. you do not efectivally "double" the damping of the ride. If you add 2 shocks that are designed to be used in a single shock setup you will have a VERY harsh ride. Dual setups are rated lower individually so this does not happen. When you see triple kits, this is even more critical. Any engineers out there will now that "C" (a dampening constant) plays a large role in the equation for damped harmonic motion, which is a way to correlate suspension travel. That is why frames will crack when the dampening rate is doubled.
79F250isalive!
03-01-2015 07:32 PM
rsfabrication
02-09-2011 09:42 PM
bugsy
10-12-2002 05:28 PM
