2008 4.2L V6 Shuts down while driving
Old 02-01-2013, 11:59 AM
JNovelli's Avatar
JNovelli
JNovelli is offline
Hello,
The other day I was pulling out of a parking lot into traffice and my truck shut down, no warning, I was able to coast into another parking lot, turned the key off, started with no issues and made it to my destination. Yesterday the same thing occured, no warning just shut down. My truck has 47,000+ miles on it. Any insight as to where to start trouble shooting would be very much appreciated. Thank you!
Old 02-01-2013, 05:50 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
check for codes, TPS or Fuel Pump Control Module
Old 02-01-2013, 06:03 PM
JNovelli's Avatar
JNovelli
JNovelli is offline
Thank you!
Thank you, I will look for those codes. Again, thank you, for your insight.
Old 02-02-2013, 11:58 AM
JNovelli's Avatar
JNovelli
JNovelli is offline
Update:
I went to the local parts store and had them plug in a code reader. I was throwing a P0109, which is a M.A.P sensor. I have determined that I do not have an actual map sensor, but it is part of the egr module. I have located a test to see if the the sensor is bad or not. I have cleaned my throttle body. I'm about to go drop the spare tire to check the fuel pump module. I will update as I run through my trouble shootings. Again appreciate the insight!
breno1987
34
03-08-2019 08:53 PM
dworth24
1978 - 1996 Big Bronco
06-24-2017 04:30 PM
jurban
06-02-2012 09:29 AM
JMC302
23
07-28-2010 12:36 PM
beave1976
05-20-2005 07:09 AM
Quick Reply: 2008 4.2L V6 Shuts down while driving
