Difference between ICP sensors - Ford Truck Enthusiasts Forums
Old 02-01-2013, 09:38 AM
cbr600rx7 cbr600rx7 is offline
cbr600rx7 is starting off with a positive reputation.
What is the difference between the 94-96 ICP sensor and the 97-03 sensor. The sensor on the 96 is starting to leak however I have a good sensor off of a wrecked 2001 SD. If I can use the sensor from the latter model truck I save $140 bucks.
Old 02-01-2013, 09:56 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
They are the same.
The 6.0's are different.
Old 02-01-2013, 10:14 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Sorry to step on your pee-pee Talyn, but I got to disagree with you here. No they're not the same. They are different parts. How, I don't know, but there are two different part number for pre '97 and post '97. They're shaped different too. I put a post '97 one in my truck and it ran, but it acted a little strange. I don't know what the functional differences are, and for all I know they may be interchangeable, but they are certainly NOT the same.
Two different part numbers too.
Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts
For what it is worth Riffraff used the same picture for both part numbers, but the shape of that sensor is the later sensor. The early sensor is round at the top and has a smaller hex section underneath.
Old 02-01-2013, 10:47 AM
I hope some one can shine some light on this. What do you mean it acted strange?
Old 02-01-2013, 11:00 AM
It ran okay, but it ran different than it does with the "older" one. It idled a little rough and wasn't as smooth.
Old 02-01-2013, 12:47 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
Go ahead and use the 2001 sensor.....The older one uses goldish terminals and the 97 and up used a silverish terminals inside the sensor....they are interchangeable... just avoid the 2 piece ones and non OEM....
Old 02-01-2013, 01:59 PM
So then, are they interchangeable? I'm just curious because I have several and they're not all the same type. I guess I should compare the resistance of them side by side and see if they read the same or not.
Now that I think of it, if the operating resistance of the sensors wasn't the same you couldn't cross over the PCMs between the years either (which you can). They must have just changed the design. I wonder why Ford still offers both sensors then.
Old 02-01-2013, 02:17 PM
Talyn's Avatar
It's a pressure sensor.
I'm sure they made adjustments too it.
But all it does is read oil pressure.
The 6.0 sensor is the same way, but it has different threads on it.
Old 02-01-2013, 05:25 PM
blageurt's Avatar
Exactly .....
Old 02-01-2013, 10:19 PM
I was not aware that you could use a latter powerstroke PCM on the older trucks. I know that the 100V and 120V IDM's can be swaped.
Old 02-04-2013, 07:57 AM
You can't use the SD (99 up) PCM on the OBS (94.5-97) trucks but the PCMs between different years of OBS trucks can be interchanged as long as you keep the transmission the same between the trucks. That being said the later PCM's had a little better base program in them.
Old 02-04-2013, 10:22 PM
So the ICP sensors are interchangable with out any issues then?
MAP and EBP Torque reading JWink 1999 - 2003 7.3L Power Stroke Diesel 64 07-27-2014 07:29 PM
2 different ICP sensors for 7.3 Ken_C 1994.5 - 1997 7.3L Power Stroke Diesel 5 06-27-2014 05:56 PM
6.0 icp sensor USMCveteran 6.0L Power Stroke Diesel 11 11-18-2013 01:22 AM
icp sensor problem giancarlo 1999 to 2016 Super Duty 3 04-19-2011 03:39 PM
Icp sensor jboard 1994.5 - 1997 7.3L Power Stroke Diesel 0 06-11-2009 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
