February General Thread - Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Old 02-01-2013, 05:24 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Alrighty guys, we are into the second month of 2013! Where the heck did January go?
First off, here is the meet thread for this month.
http://www.ford-trucks.com/forums/12...uary-meet.html
I know some of you fellow WAFTEers live more central/Eastern washington so if you guys who don't live close enough to use want to make your own meets that are closer then go right ahead! I feel kind of bad since a few of us western side guys are meeting up, seems like those of you on the eastern side who are too far away are being left out.
Anywho, welcome to February everyone!
Old 02-01-2013, 11:47 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
But for the summer this is this
http://www.ford-trucks.com/forums/12...-together.html
Get the camping gear in good shape and come to the BIG meet
Sean
Old 02-02-2013, 12:38 AM
Sean
That's true, I kinda forgot about that thread. Hopefully more will sign up.
Old 02-02-2013, 01:52 AM
crash1's Avatar
crash1 crash1 is offline
crash1 is gaining momentum as a positive member of FTE.crash1 is gaining momentum as a positive member of FTE.
hello hello boooyaaa
Old 02-02-2013, 04:28 AM
Yahiko's Avatar
Oh BTW on my new tuner with the SRL from Matt
have a look at this image and tell me if you see
the nice 0
Mind you that the truck has been running for more than an hour
so it's nice and warm. There is more than one way to skin a cat
or delete the EGR system. AND if I have to it takes less than 5 minutes
to turn it back on for the state snoopers.
Sean
Old 02-02-2013, 11:51 AM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
Good morning neighbors to the north, another month gone by.
Old 02-02-2013, 04:18 PM
Happy afternoon guys.
Old 02-02-2013, 04:46 PM
Yahiko's Avatar
Time for Diesel play time to start.
I read where the TOY EFFECT may not go away with age.
I am off to play with the new tuner in my truck.
Sean
Old 02-02-2013, 04:56 PM
Play with your new tuner and buy some new rear tires eh? Just don't leave any tire tracks by my house, that's my job
Old 02-02-2013, 10:28 PM
Yahiko's Avatar
I was told that I can leave a set in 4X4 and by the way it took off last night
I bet it would. That and the black smoke cloud.
I am learning how to not kill my MPGs with a heavy right foot.
The truck really responds well and very snappy now. No more sit and wait
for the turbo to spool up.
Sean
Old 02-03-2013, 01:53 PM
That's good.
So who do you guys think will win the superbowl today? All my eggs are in the 49er basket.
Old 02-05-2013, 05:19 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
well boys, thought i'd give you an update on my engine progress. so far i have the crank, cam, and pistons installed, all bearing clearances checked out, and making progress. taking a lunch break right now, but when i head back out i'll clean and install the oil cooler, oil pump, front and rear main seals, oilpan, etc. then i get to flip it over and screw in my head studs and have all kinds of fun
Old 02-05-2013, 07:37 PM
and now we get to have more fun with a miscalibrated torque wrench.
as i said above, i had the rods all torqued down and had moved on to the oil cooler, when i realized that the spec i had my wrench set to didn't feel anywhere close to the response the bolts were giving me.
so i stopped and compared that torque wrench to another, and found it was about 10 ft-lbs below all my others for the same setting. so after i recalibrated it to match my other torque wrenches, i returned to the rod caps. some of them needed nearly 90* to reach the torque spec now that the wrench is calibrated. my torque values feel a lot better now.
this is at least the third time i've had one of my harbor freight torque wrenches lose calibration on me, but in the past its always happened when the jam nut at the adjusting sleeve comes loose, this time that was taped down and secure, but it had changed all by itself.
i guess thats why they're so cheap
Old 02-05-2013, 08:35 PM
Nice to see you are making a lot of progress. At least the torque wrench was 10 under and not 10 over tot he point of snapping heads off... That wouldn't be fun.
Old 02-06-2013, 03:17 AM
yeah, i'm glad it was off that way not the other!
my trick for calibrating them is to connect them head-to-head with a known good torque wrench, set at the same setting - i used 60 ft-lbs this time, and comparing how close to each other they click. the other 2 torque wrenches in my box matched each other perfectly, so i used one of them for my standard of whats right, then adjusted the one i was using until it matched.
i tried to get the rear main seal on there before i had to run off to a meeting this evening, but screwed up the seal just about as soon as it touched the crankshaft, so i got another one and get to try again in the morning. the first one was labeled as being made of PTFE, the same stuff as your pipe thread seal tape, and the seal material was horribly brittle, it came with a plastic install sleeve, and thats what folded the seal lip over, and as soon as it started to fold, it cracked. the seal i picked up tonight is made of a more conventional rubber, and should install normally.
KY-OH Chapter meet? SideWinder4.9l Ohio Chapter 19 08-19-2013 12:32 PM
2013 Meet Country705 Kentucky Chapter 33 03-03-2013 10:14 AM
February Open Chat Thread 67 Olfthfl N. California Chapter 172 03-02-2012 10:27 AM
February GTG - Beer and Pool donjamer Massachusetts Chapter 15 02-15-2009 03:39 PM
February meeting... Patatoe1 Illinois Chapter 9 02-24-2006 01:07 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
