Australia Chapter Join Chapter , Leader: ChunderDownUnder
200amp Alternator Install
Old 03-24-2013, 03:12 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
The so called drop in 200amp alternator aint so.
The area circled sits about 10mm lower than the stock at the front and back.
So you are going to need a grinder.
take a little of the bracket and all is good
Old 03-24-2013, 03:27 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Brian:
1) good to see you wearing the Taiwanesse saftey boots!
2) was the grinding of the mount the only mod necessary to fit the 200 amper?
3) How much cheaper was it than the FA $6000 replacement, w & w/o freight?
4) How long were you waiting & which transport option did you go for?
Back on the road again?
Old 03-24-2013, 04:23 AM
ChunderDownUnder
$250 Delivered. And it took 11 days.
Yes the grinding is all that is needed.
Not on the road yet. I cracked my Map sensor when I was putting the IC tube back on. I tried super glue but she is leaking like a sieve. Found one down in Victoria. Hopefully get it by Tuesday.
Old 03-24-2013, 06:31 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Something like this?:
3 BAR MAP SENSORS DELCO STYLE TURBO SUPERCHARGED WITH PLUG | eBay
except you'd need a 4 bar capability (atmosphere + 45 psi)?
Old 03-25-2013, 05:34 AM
ChunderDownUnder
seth.pat
08-10-2014 07:20 AM
MeWoahIts
09-09-2012 07:00 PM
Skyline Drive
18
12-05-2011 11:16 AM
polishdude20
06-09-2010 10:00 PM
gmk035
07-08-2009 03:10 AM
Quick Reply: 200amp Alternator Install
