need steering gear box for 1960 f600 - Ford Truck Enthusiasts Forums
Old 01-31-2013, 11:34 PM
4 eyes f600 4 eyes f600 is offline
4 eyes f600 is starting off with a positive reputation.
I need a new, rebuilt, or parts list and availability for steering gear box for my 1960 f600 truck. I saw where Number Dummy helped a fellow find parts to rebuild gear box on his 1962 f600. I feel sure mine is obsolete also, so if it is obsolete I am listing all info. on the glove compartment i.d. plate.
VIN #F60CON16398
Model #F602
Trans: F
Axel: N1
Max. GVW: 19,500
HP 146 @ 3,800 RPM
DSO: just shows 2 stars
WB 172 J
THANKS!!!!!!!!!!!
Old 02-01-2013, 10:50 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Four eyes; Is there still an ID tag on one of the four bolts on the bottom of your gear box or a casting number on the box it self. These numbers will help to get the correct repair parts for that gear box incase it has been changed through the life of the truck.
I'm sure Bill will be along when he can.
Old 02-01-2013, 11:19 AM
59Terry 59Terry is offline
59Terry is starting off with a positive reputation.
LMC parts has a rebuilt one as well as most of the parts for that model
Terry
Old 02-01-2013, 12:41 PM
steering gear box
There is no ID tag; but the housing casting # is 4CC25
THANKS!!
Old 02-01-2013, 12:46 PM
Thanks for your help; however, I am fairly new at this; can you tell me who is LMC and how can I get in touch with them?
Old 02-01-2013, 04:54 PM
I gave you bad info on that stearing box.LMC does not sell parts for f600.I guess i need to read more and speak less.sorry
Old 02-01-2013, 07:32 PM
Refyred
This what Bill posted in 2006
Quote:
Sectors
1959/60 F600
B7Y-3575-A sector, steering shaft
Front Axle: 4M, 4, 7M;
Housing number: 4CC25
Complete Assy: B7Y-3504-A
OR
B7Q-3575-A sector, steering shaft
Front Axle: 6M;
Housing number: 5DC25
Complete Assy: B9T-3504-B
Note: 1959 & 1960 F350's w/3.8 Gemmer use the same steering box as the first F600 sector (B7Y-3575-A) I listed above
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Here is the thread
http://www.ford-trucks.com/forums/56...00-sector.html
Good luck in your quest!
Old 02-05-2013, 09:02 AM
FJones8668 FJones8668 is offline
FJones8668 is starting off with a positive reputation.
I believe that it is dennis carpenter that always advertises reman f600 steering boxes
check them out
http://www.parts123.com/parts123/yb....Z5Z5Z50000024G
Old 02-05-2013, 08:32 PM
Thanks! I will check it out.
Old 02-07-2013, 06:11 PM
Just in case anyone else is having the same problem as I am, Dennis Carpenter no longer carries reman. steering boxes for f600 trucks. I checked with them today.
4 eyes f600
Old 02-10-2013, 09:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
B7Y-3504-A .. Steering Gear Assy-Use with housing marked 4CC25 / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Your only choice is to buy the individual parts or send the box to Seattle WA and have it rebuilt by redheadsteeringgears.com
I'd be very leery buying parts from LMC. Since there are two different gearboxes for these trucks, how will you know if they have the correct parts for yours?
You will need: Steering shaft and worm, the bearings and cups for it. Sector shaft (B7Y-3575 A - 15 available NOS) and bushings. Shims, housing gasket, a sector shaft seal and etc.
If you wish, I will look these parts up, see what I can find NOS, as all are obsolete.
Old 02-10-2013, 10:13 AM
Thanks Number Dummy
That would be great if you would do that for me since I seem to be hitting a dead end. I was hoping that you would respond; THANKS again for any info. that you send me!!
4 eyes f600
Old 02-10-2013, 10:16 AM
4 eyes f600
Will list all the Ford part numbers, sources later today.
Old 02-11-2013, 01:52 AM
1960 F600 Steering Gearbox Parts ~ Housing # 4CC25
B7Y-3524-A .. Steering Shaft & Worm / Obsolete
1) BB-3552 .. Steering Shaft & Worm Upper Bearing Cup / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 11 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 13 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 19 = 888-727-0418.
1) 81T-3553 .. Steering Shaft & Worm Lower Bearing Cup / Obsolete
CARPENTER NOS OBSOLETE has 5.
GREEN SALES has 7.
PARTS INTERNATIONAL has 7.
2) 81T-3571-A .. Upper/Lower Steering Shaft & Worm Bearings / Obsolete
GREEN SALES has 1.
PARTS INTERNATIONAL has 17.
B7Y-3575-A .. Sector Shaft / Obsolete
CARPENTER NOS OBSOLETE has 1.
GREEN SALES has 14.
2) B7C-3576-A .. Sector Shaft Bushings / Obsolete
PARTS INTERNATIONAL has 23.
GREEN SALES has 152.
7RT-3581 .. Sector Shaft Cover Gasket / Obsolete
CARPENTER NOS OBSOLETE has 18.
GREEN SALES has 144.
B6A-3591-A .. Sector Shaft Seal / Obsolete
PARTS INTERNATIONAL has 16.
CARPENTER NOS OBSOLETE has 38.
GREEN SALES has 49.
AR) 81T-3595-A .. Steering Shaft & Worm Cover Gasket / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has 20 = 607-722-5371.
CARPENTER NOS OBSOLETE has 40.
7RT-3738-A .. Steering Shaft & Worm Seal / Obsolete
PARTS INTERNATIONAL has 50.
GREEN SALES has 55.
AR = As required. There are no shims listed, so this 'gasket' may be a shim.
Old 02-11-2013, 09:25 AM
Thanks again Number Dummy
Just wanted to say thanks again to you Number Dummy; that info. is VERY helpful. I will post an update when I finally get steering box rebuilt but it may take awhile.
4 eyes f600
1960 F100 Styleside Shortbed Tailgate rvarner 1957 - 1960 F100 & Larger F-Series Trucks 14 09-26-2015 11:49 PM
WTB 1960 F100 steering box Divingjack WTB - Parts & other 0 12-13-2014 11:46 PM
Brake data for1960's Ford N or F600, etc N600 Large Truck 1 10-22-2013 07:03 AM
F600 Steering Box Larry Schadewald 1957 - 1960 F100 & Larger F-Series Trucks 15 07-27-2013 03:20 PM
F600 steering box for a '60 wademo 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-25-2007 06:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
