What Shocks For Quad Front awa Rear?
Picking up from the discussion in Dad's Truck Build re shocks, but posted here to close the loop, I just called Monroe's tech support line and talked with Adam. According to him the better shock for this application, meaning quad shocks and on-road driving, is the Sensatrac. It is set up to give smooth response until you hit dips/bumps, at which point it will firm up. The Reflex will firm up things at all times, and having four of them will make it much stiffer.
Given that I'm ordering Sensatracs for the front and Gas-Magnum's for the rear.
In the under $10 category they have one Gas-Magnum for the rear of a half-ton and one for a 3/4 ton, both for non-4wd. But their price on the right part # for Gas-Magnums is close to Amazon's.
(Maybe I'm wrong?)
Gary,
Look under 'factory ride' or whatever.
Wholesaler closeouts/
The Sensa-trac's are as I posted in #13.
The target is an '81/ F-150/ 5.8/suspension/ shock absorber/ original ride quality/ 4X4
Monroe Sensatrac, Wholesaler closeout #37095= $9.58
***edit; the 37036 seems to be $27.79
But the Reflex 911036 is farther down at $19.68***
Do I need to take a screenshot?
I can't seem to copy & paste from their drill down page.
Gary,
OOOOOPPPPS! I hadn't scrolled far enough down! Found them! They don't fully sort by price, but have categories of HD, Original Ride, etc and sort by price w/in those categories. The Sensatracs are in Original Ride Quality. However, I need part #...36 & ...95, and they don't have the 36. I think the 34 is for non-quad setups, but I haven't checked. Anyway, I found them. Thanks.
Headed out now for a day in T-town. James just called from Inland and the drive shaft is ready, so we'll pick it up today. Anyway, I'll order later today, hopefully.
Jim - Driveshaft's mug is posted, as requested.
GF - Glad it helps. Keep reading.
This was also posted in Dad's Truck Build, so if you think you've already read it you may have. But, it needs to be here as well for posterity.
I talked with Adam at Monroe again this afternoon, this time about rear shocks for the truck. His recommendations were:
So, I guess I'll go with Sensatracs all around.
- Gas-Magnums: Best if the truck is going to be used loaded more than 75% of the time. They'll handle the load very well, but will give a harsh ride when unloaded.
- Reflex: Give the best handling the truck is capable of and would be good if the truck is loaded a lot of the time. But, will not have a smooth ride when unloaded.
- Sensatracs: Best for trucks that aren't carrying heavy loads frequently. Will give the best ride and good handling as well. And, when the truck is loaded and the rear sags a bit the valving will move into the "firm" position and it will handle the load quite well. Given what I told him about how I use the truck he strongly recommended them for Dad's truck.
Just ordered 6 Sensatracs from Amazon:
- 2 ea for the rear @ $30.58/ea
- 2 ea for the front ahead of the axle @ $30.58/ea
- 2 ea for the front behind the axle @ $27.52/ea
I think he might have his info mixed up on what the engineers did. All of the catalogs I have show the radius arm shock being the same, regardless of quad shock or single shock. There are differences between LD and HD, but they mount the exact same way on both.
From what I see, there's a part number for the front shock exclusive to Quad Shock trucks, there's a part number for the radius arm shock that is the same between single and quad setups, there's a part number for the rear axle shock on a 4x2, and a part number for the rear axle shock on a 4x4.
I physically do not see how removing one shock from the quad shock equation will matter at all, aside from a change in ride quality. He makes it sound like the primary shock is gonna fall out of the truck if you remove the secondary shock.
#28
No, that's not what he conveyed to me, so I've said it wrong to you. He wasn't saying it would fall off but that it wouldn't work correctly.
As for bolting on, he may well have been wrong about the rear shock of the quad and the shock from the dual setup being different from a length standpoint. And, I may have interpreted what he said incorrectly. However, Monroe has a different part # for the rear shock of the quad as opposed to the dual setup. Ford may not, but they do.
#29
I'm not entirely sure why Monroe has a different part number for the radius arm shocks. I just played with the "Does It Fit" function on Amazon, but instead of choosing 4x4, I chose 4x2. It gave me the same part number for the radius arm shock as it did for your 4x4, 37095
#30
