Blue Smoke and 1.5qts low on oil - Need help
Old 01-31-2013, 02:33 PM
dc3655's Avatar
dc3655
dc3655 is offline
Question Blue Smoke and 1.5qts low on oil - Need help
My 2005 PSD has started to blow blue smoke, especially when accelerating from a stoplight/stop sign. I checked the oil today and it was not on the dipstick, so it took 1.5 quarts of oil to get it back on there. I now know I'm burning oil from somewhere. I've read that it could be a seal in the turbo. My turbo was replaced under warranty 2.5 years ago with a 2007 model, but I've not had any boost problems lately.
Any help would be appreciated. Thanks in advance.
BTW, I use Rotella 5W40 Syn, fuel additive at every fillup, and just ran 4 oz of Rev-X for the fun of it even though I wasn't having any stiction issues.
Old 01-31-2013, 03:07 PM
maverick600's Avatar
maverick600
maverick600 is offline
My suggestion is only from past experience with V8's and old engines but i would say either your piston rings or valve guide seals are worn. But could be wrong since I assume its a diesel.
Old 01-31-2013, 07:16 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
The First Spot Id check is the Down Pipe Out the Back the TURBO
theres a pic somewhere of the Oil Swirl
Old 01-31-2013, 07:18 PM
cheezit's Avatar
cheezit
cheezit is offline
what he said
Old 01-31-2013, 07:22 PM
BLADE35's Avatar
BLADE35
Maybe the BellHouse see if it has a Drip or anything its easy anyway
Old 01-31-2013, 07:23 PM
BLADE35's Avatar
BLADE35
Maybe the Look BellHouse see if it has a Drip or anything its easy anyway
Old 01-31-2013, 08:55 PM
dc3655's Avatar
dc3655
dc3655 is offline
Thank you all for the replies! The truck is going under the knife on Monday to update all the parts that have changed from Ford/International including a BPD EGR cooler. I'll have the mechanic check for the "oil swirl" in the downpipe. If it is the turbo causing this, how hard of a fix is that? Or will I need a new turbo?
Old 01-31-2013, 09:24 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
Hey DC, this is what my truck looked like when I broke the shaft in the turbo. It blew 1 1/2 gallons by the time I got it parked at a hotel.
I'm sure my housing was shot,,, but I looked for a rebuild kit that included the shaft,,, couldn't find one.
But there are rebuild kits for a blown oil seal.
Old 01-31-2013, 09:35 PM
BLADE35's Avatar
BLADE35
Thie was from the Main Turbine Shaft Breaking Anothony???
Any Pics of the Carnage???
Old 01-31-2013, 09:41 PM
Fal-308-Win's Avatar
Fal-308-Win
Fal-308-Win is offline
No West Nile Virus there, all the Mosquitos are dead! !!
Old 01-31-2013, 10:28 PM
run6.0run's Avatar
run6.0run
Yeah, lme dig em outta the photobucket acct.
Also, the fire dept showed up. It looked like fog. It literally covered the whole interstate,, both ways,,, I was climbing vail pass n co. Lemme look for the pics
Old 01-31-2013, 10:37 PM
run6.0run's Avatar
run6.0run
Here's one
Old 01-31-2013, 10:39 PM
run6.0run's Avatar
run6.0run
I only have that one. But the exhaust turbine was just sitting in there. I still have the turbo.
Old 02-01-2013, 01:54 AM
dc3655's Avatar
dc3655
dc3655 is offline
Wow, I'm glad that I'm nowhere near this amount of smoke billowing out the exhaust. Mine is just a haze compared to this.
That makes my day to know that there are rebuild kits for the blown seal. Do you know where I can get one? Thanks for your help.
Old 02-01-2013, 09:19 AM
run6.0run's Avatar
run6.0run
One place I found is called"papa" something. Can't remember off hand. Maybe someone else will chime in with a link or something.
Quick Reply: Blue Smoke and 1.5qts low on oil - Need help
