Just pull the valve cover and replace the gasket.....use a thin layer of non-hardening make-a-gasket compound on both sides of the gasket.
Not a good idea on his truck. the intake is one half, and the head is the other half. The gasket maker will contract and expand at different rates. Felpro makes a blue silicon gasket that does well. You still will have to put permatex at the 2 spots where the intake meets the head, which BTW, is probably where the oil leak is.
Originally Posted by GIGGER
I don't need Charlies help Rob, I can fix that easy.......
NO NO NO. he'll fill your motor with Plaster of Paris. The oil leak will stop, but only because the motor locked up!!!
