Edge vs Escape - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Edge vs Escape
Old 01-31-2013, 09:44 AM
hop hop is offline
hop is starting off with a positive reputation.
Edge vs Escape
I posted this under Edge but want to hear from the Escape owner, also.
Consumer Reports gives higher marks for the Escape than the Edge but both are lower than the competition. The Edge is given low marks for reliability but I have not seen any consumers expression a common problem other than with MFT and the CR history gives good marks for the last 3 years. Are the maintenance and resale value really that bad?
Which to pick? The cargo room is nearly the same although the Edge looks bigger. The Edge is heavier with a V6 better for towing and I would expect ride better and be better in snow and mountainous driving.
While the mpg of the competition 4 banger's is a big plus, they are noisy and probably not as comfortable on cross country trips, especially through mountains. The Explorer appears to have mixed views and also, given low marks by CR and it's a little larger than I really need but haven't completely discounted it.
I'm looking for the best fit 5-7 passenger for long drives, camping, and mountains. MPG is a big factor but I want power to get up mountains and around pokes.
Let me hear your side.
Old 02-01-2013, 06:55 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Unless your passengers have been on a diet, 5-7 people aren't going to fit into an Escape, and likely not into an Edge. The Escape has 5 seat belts, ergo, 5 passenger. The Edge, I think, is the same. I think the Escape has more room, but don't know if it will seat 7 either.
If you want some size, with even decent mpg, take a look at the Flex. They have room, and actually are better on mpg than the Escape. How? I don't have a clue, except their engine is .5l larger, and may be geared for longer legs???
tom
Old 02-01-2013, 08:45 AM
tcesni tcesni is offline
tcesni is starting off with a positive reputation.
I rode in the backseat of an Edge this week and it is quite a bit wider and felt roomier than my 09 Escape but I haven't sat in the new 2013 Escape. The interior was certainly more luxurious and quiter than my Escape but I think the new Escape has made strides in that area. Fuel economy is similar so I suggest you take both for lengthy test drives (maybe even a weekend rental) before deciding. Most of the negative comments from CR comes from their dislike of Ford's Sync infotainment system.
Old 02-01-2013, 10:39 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
The edge does have more back seat room but the mpg is horrible. We have the Tribute and my best friend has an Edge and we have used both to tow our two sport bikes from Dallas to Chicago and the edge gets about 4 less mpg but it is better ride.
Old 02-01-2013, 10:51 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I agree that neither one of those vehicles are going to fit 7 people.
The flex is a nice option for more then 5 passengers. You will obviously need something with a third row.
As for the Escape vs Edge, I vote Escape for the ground clearance. Here in the mountains, ground clearance goes a long way in the winters.
Old 02-14-2013, 11:00 AM
Jonas1022's Avatar
Jonas1022 Jonas1022 is offline
Jonas1022 is starting off with a positive reputation.
2008 Tribute/Escape
We have a four pot Tribute/Escape with auto. It does well on the highway, but loaded to maximum, that little engine is taxed. If most of your driving is unloaded, with only one or two aboard like us, it's great. We usually get over 30 mpg and have seen 33 a few times on the highway doing 80 mph. Usual duties are around town with an errand or two in mind. City driving with lots of stop and go it's getting about 22-23 mpg and is quite peppy. A buddy has and Edge, it is larger outside and inside. Seats 4 up very comfortably and the V-6 is a help when fully loaded, but not such a good buy for the additional $10K over what we paid for our SUV. MPG is somewhat less than the Tribute. Depends on your driving habits and needs I suppose.
No issues with our Tribute. Nothing on the later Edges either. Earlier examples had some minor recalls. That is all.
Darin's Daily Rant dmp Michigan Chapter 74 06-25-2015 03:31 PM
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 01:47 AM
THIS is what ill be driving 351Cleveland C4 The Next Generation 23 09-23-2013 07:00 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 11:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
