Headlights randomly coming on?
Old 01-30-2013, 08:54 PM
Yougotthehit's Avatar
Yougotthehit
Yougotthehit is offline
Truck was just parked sitting there and the lights came on. Changed the headlight switch and it was fine. 5 hoursater the lights are back On????? It's a 00 f350 what gives
Old 01-30-2013, 09:10 PM
AzPete's Avatar
AzPete
AzPete is offline
Truck is afraid of the dark......
Any changes to the system from the stock lights?
Old 01-30-2013, 09:16 PM
Yougotthehit
Nope bone stock
Old 01-30-2013, 09:42 PM
AzPete's Avatar
AzPete
AzPete is offline
Unplug the headlight switch and see if it happens again. Possibly a bad....new....switch.
Old 01-31-2013, 08:10 AM
Yougotthehit
I highly doubt that
Old 01-31-2013, 09:00 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
It is sending signals to a another ship in the distance. It's lonely. Get another truck!!
Sorry... Too much coffee....
Check the back of the fuse box and check the GEM for signs of dried up water.. Corrosion etc.
These trucks are known for leaking windshields at the top drivers corner. The water runs down the A pillar and into the back side of the fuse box and on to the GEM. The GEM is what controls the accessories. There have been other wierd things happen when that gets wet... Truck dies when using the wipers, Radio comes on and off on its own etc.
And dont ever believe that anything new is working fine unless you have tested or proven that it is good. I have seen many switches DOA out of the box. Although the same exact issue with a new switch is unlikely, but not impossible.
Old 01-31-2013, 12:17 PM
Yougotthehit
Thanks buddy
Old 01-31-2013, 01:23 PM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
Can you tell if it's your high beams or low beams that are coming on. It could be your multi function switch or a chafed wire in the column.
Old 02-08-2013, 08:14 AM
Yougotthehit
Ok. So now the parking lights come on and stay on unless you unplug the batteries. I disconnected the head light switch to see if that would do it and even with it unhooked they are still on. I'm lost!
Old 02-08-2013, 08:28 AM
BillyBob69's Avatar
BillyBob69
I still think the GEM module is having issues. Have you tried just unplugging that? Or checking for water marks?
Old 02-08-2013, 08:37 AM
AzPete's Avatar
AzPete
AzPete is offline
Yep....sounds like a water leak issue or GEM issue for sure.
Old 02-08-2013, 09:02 AM
howellt39's Avatar
howellt39
howellt39 is offline
Agreed, start with the GEM. Has it been parked outside or driven in a lot of rain lately? Leaks from the windshield seal seem to make their way directly to the GEM.
Gonna throw my hat in the ring for bad switches out of the box. Had a bad one show up for my wife's Jeep. Entirely possible. I don't think it's your problem, but yeah that's not unbelievable in general.
Old 02-08-2013, 09:32 AM
99StrokeXLT's Avatar
99StrokeXLT
99StrokeXLT is offline
Don't want to high-jack but what is the solution for a leak at the windshield. New window/reseal?....
Old 02-08-2013, 09:43 AM
BillyBob69's Avatar
BillyBob69
Most reputable shops can pull, clean and reseal the windshield correctly. Just have them give a little more attention to the top corners...especially the drivers side. That is usually where it has problems. Water collects in that spot then rusts and starts draining into the cab.
About 3 windshields ago, the guy installing it saw the bad spot and did some repair to it. Cleaned the rust, JB Weld to close any pin holes, primered the bare metal and kept it all below trim line so when the windshield was put in, you couldn't see the repair. Just be sure that if you do have this done... If the guy seems unsure at all, don't let him do it. I have seen good windshields destroyed by someone not being careful taking it out.
Old 02-08-2013, 09:48 AM
99StrokeXLT
Thanks, I'll have to take a look in there my radio randomly tires to load a CD when there hasn't been one in there in 2 years. Happens with the radio on or off, then switches back to FM.
Quick Reply: Headlights randomly coming on?
