sound insulation
#32
#34
#35
#36
Are you working in a heated garage? Most products I have used stick to cool metal, but I wouldn't do it in anything close to freezing temps. If it isn't warm out I hold the product up near a heat source. My wall mounted NAT Gas heater works awesome. I have seen people use heat guns, hair dryers etc.
#38
No, no heated garage....i've got a daisy propane heater, but that's about it....sounds like the wifes hair dryer is going to get some overtime work.......;
leaning toward the RAAMT product........sound deadener looks good too, but confusing on application.......Dynamat looks good too, but...spendy......; just damn confusing......want ease of application and sure don't want any tar/odor........also, the deadening and absorbtion differences........just need to decide and pull the trigger...
#40
Everything you mentioned will sound deaden your truck. None of the products smell. You haven't mentioned a 2000 watt stereo so just pick one you like. If you install now, warm it up best you can and for a good while. As Horvath mentions condensation is not your friend. You won't be the first to do it in cold weather based on audio threads I have read.
#41
#42
#43
#44
Hey guys......did some reading on the por-15.....sounds like something i should do prior to the sound insulation. the floor has a fair amount of surface rust (mixed in with painted/bare spots.....anyone used this.....looks like something i should do.
Thoughts?
Thanks guys!
Thoughts?
Thanks guys!
I just ordered another quart can today, but have the bottom of the cab, inner fenders, and some misc. parts to paint. If I do have any left I am going to put the remaining liquid in a water bottle. This works somewhat well. (Also from previous experience)
