sound insulation
Guys, REALLY appreciate all the feedback. Sounds like there are quite a few good options out there. Are you guys using the same materials under (above) the headliner? I've heard some of the products can come loose and hang under hot, sunny weather....THAT would be bad....
Any experiences with that?
Thanks again!
Scott
Thanks again!
Scott
I use a generic brand of dynomat, then painted over it with bedliner like heat/sound spray. I sanded the cab to provide better adhesion and do not anticipate any problems. I am using the brush on sound insulation on the floor mat stuff, did not want to put it on the ceiling for the same reason you mentioned. I also bought the products from LMC (macs carries too) for the insulation type panels to go over everything else....
Hoping for a quiet ride and one that will hold heat... Not running air so the more heat I can keep in the engine bay the better.
Good Luck on your choice. I have pics on my thread, I am cheap and did not use the mat as a solid layer, but have read it works nearly as well as the full coverage.
I used the vibration dampener (black sticky) panels and 1" 3M thinsulate pads above the headliner (from Don at sound deadener showdown) they seem to work well, its hard to remember how loud it was before. Living in southern Nevada desert I have used the sticky panels from both of the venders I listed above with no adhesion problems during the summer time.
Good luck in your quest.
I used home made lizard skin (hmls) on all interior surfaces. Go to hotrodders.com, general rodding tech, I think. There's a thread on making your own lizard skin. It's cheap and it works. Over that is peel and seal from lowes. I've had no problems with melting or smell as some have claimed. It's been parked in 105 degree heat, windows up and no problems. On the roof and vertical surfaces I used contact cement along with the adhesive that's already on it. I'm happy with the results and I have less than $100 invested.
....... It's cheap and it works. Over that is peel and seal from lowes. I've had no problems with melting or smell as some have claimed. It's been parked in 105 degree heat, windows up and no problems. On the roof and vertical surfaces I used contact cement along with the adhesive that's already on it. I'm happy with the results and I have less than $100 invested.
Oldford, that's exactly what I'm talking about. Home made lizard skin. Wicks aircraft supply sells the glass microspheres. I understand they are used by the model aircraft folks in their fillers. Miss tint exterior latex paint can be purchased for a couple of dollars a gallon. You may even be able to have them change the tint somewhat to make it more liveable unitl you get your interior done. One gallon, mixed pretty thick with the microspheres, covered my interior with two coats brushed on.
Nothing exciting. Future old Ford projects are on hold while I build spare engines for no apparent reason. There is something very wrong with me
My Cherokee is getting some audio and thought it would be a good candidate for some sound deadening. It's lifted, noisy and heavy so a good test. Most sound deadeners are very heavy and I don't need more weight on the Jeep.
#29
Check out Reflectix, avialable at home depot:
The World’s Largest Manufacturer of Reflective Insulation and Radiant Barrier Products
#30
Fenders, I read all about hmls on hotrodders . com, in the general rodding tech forum. It's a multi page thread that's been going for quite awhile and it's on the first page right now. There was some disussion as to spraying or brushing it. I didn't want to buy a gun just to spray it so I mixed it alittle thicker and brushed it. One gallon of paint, split into two cans to make mixing easier. Enough glass balloons to get to almost a peanut butter consistency, just alittle thinner. Painted the entire interior with two coats. Lizard skin says spray to credit card thickness, about .040 and that's what I got with a brush.
