Stupid mirror question - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 01-30-2013, 11:37 AM
birdnut birdnut is offline
birdnut is starting off with a positive reputation.
I have heated, power, turn signal mirrors on my 2004 excursion. Want to replace them with tow mirrors with heat, power, and turn signals. What trucks mirrors (years, models) will fit on my ex. Thanks
Old 01-30-2013, 12:32 PM
TXtinct's Avatar
TXtinct TXtinct is offline
You'll shoot your eye out
TXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputation
Should be able to fit 2001-2011, not sure if the '12 & '13's changed any.
Old 01-30-2013, 10:02 PM
mtnsammy mtnsammy is offline
mtnsammy is gaining momentum as a positive member of FTE.mtnsammy is gaining momentum as a positive member of FTE.
I have the paddle mirrors too. ried the factory extenders and they bounce so much I could not see anything. RockAuto has several to choose from but do not show the connectors. Before I buy one I want to see if it is a direct plug in or if I need to fab an adapter. the mirrors at RoockAuto are about $125 each. Not to bad for an upgrade. There are several different part numbers tho for similar looking mirrors. I will keep looking and post if I find what works.
Old 01-30-2013, 10:55 PM
kornfanjoe's Avatar
kornfanjoe kornfanjoe is offline
kornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant future
2001-2013 all fit, only difference is plug style. I believe paddle is a round plug, regular tow is a square ish plug and the 08+ have a third style. Not 100% but I know they bolt right up and that's there are 3 plug possibilities
Old 01-31-2013, 10:07 AM
TXtinct's Avatar
There is an adapter out there, I can't remember where I saw it or who makes it. I'll see if I can dig it up.
Old 01-31-2013, 10:52 AM
volthause's Avatar
volthause volthause is offline
volthause has a good reputation on FTE.volthause has a good reputation on FTE.volthause has a good reputation on FTE.
Quote:
It depends on the features of the mirror as to which plug is on it. If it is just a power adjust mirror, the paddle will have the round plug. If it's heated and signaled, it has to have the rectangular plug.
Old 01-31-2013, 02:54 PM
Thank you to all who responded. Which "F" series fit? 150, 250, 350? I had a lady at junk yard tell me F250 mirrors ould not fit.
Old 01-31-2013, 04:44 PM
TXtinct's Avatar
F150 will not fit, the others will.
Old 01-31-2013, 09:31 PM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
Quote:
On the oem 08 and newer you have to grind an aluminum tab off them, then they bolt in...
Old 02-01-2013, 12:29 AM
VQT VQT is offline
VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.
First, check your connection before buying the tow mirrows at the junk yard. I have an 04 and it is rectangular not round (bought after market tow mirros). The mirrows at that junk yard will fit if it has a rectangular plug. Also, only buy one with heated, power, and signals just like what you have now. 08 also have the power fold which I love to have.
Old 02-01-2013, 07:50 AM
Nosedive1 Nosedive1 is offline
Nosedive1 is starting off with a positive reputation.
I bought these, they plugged right into the connector on my '02 Excursion. There is an extra wire in the plug for the running light on the mirror. I ran a wire through the wire boot on the door to the running light wire on the switch so the running light feature now works on them too.
Ford F250 Truck Mirror - AM Autoparts
These did come out after I had bought the 99-07 style. They are a little more but I wish I would have gotten these.
2008 Ford F250 Truck Mirror - AM Autoparts
08 F-250 Super Duty V10 Mirrors Jumper1 Modular V10 (6.8l) 10 03-30-2015 01:40 AM
power mirrors with turn signals kyle.good 2004 - 2008 F150 2 02-09-2012 07:27 AM
Mirror Conversion edub32 1999 to 2016 Super Duty 5 03-03-2011 10:09 AM
Mirror Swap GhostF250 1999 to 2016 Super Duty 4 11-08-2010 10:54 PM
Signal/Lighted mirrors on my '01 F350 Jojiggler 1999 to 2016 Super Duty 6 03-24-2008 12:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
